coilovers
Old Mar 18, 2007 | 02:09 PM
frisc's Avatar
improvisor specialist
coilovers
trying to find out what coilover setup you guys are running on your FD's....i want to be able to lower the car 3" to 4" and still have a good ride....anyone use megan or ksport?
Old Mar 18, 2007 | 03:22 PM
rynberg's Avatar
LOL, 3-4 inches? Um, OK.
Try using the search function....
Old Mar 18, 2007 | 03:30 PM
Dorifto_PG's Avatar
I used magic. That gives me the lowest possible setting and still comfy enough for daily driver.
Old Mar 18, 2007 | 08:55 PM
jkstill's Avatar
Searching for 10th's
Have you measured the clearance under a stock FD?
I'm not a suspension expert, but I think lowering an FD 4 inches with just coilovers would be quite an accomplishment.
Maybe you need some drop spindles:
https://www.rx7club.com/race-car-tech-103/fd-drop-spindles-uprights-597888/
It's unknown just how those will affect handling.
If you do manage to get your car that low, you can forget the the good ride.
My FD is on Ground Control coilover setup with Koni Yellows and 550 front 450 rear springs.
It's about 2" lower than stock, which is plenty low.
No way a jack can get under it without driving up on ramps.
Old Mar 18, 2007 | 09:21 PM
rynberg's Avatar
This is fun so I'll just point out that the stock ground clearance is 4.5 inches.
Old Mar 18, 2007 | 10:09 PM
initial D is REAL!'s Avatar
you can do that by removing your springs and ride on just shocks. Hee hee
Old Mar 19, 2007 | 01:13 AM
TRISPEEDFD3S's Avatar
FEED me
or take out your shocks and springs, and wazam! You have air suspension!
Old Mar 19, 2007 | 12:58 PM
frisc's Avatar
first i want to say thanks for the smart **** comments but what i ment was what coilover setup has a nice ride when low....Im not gonna slam it to see how long it takes for my mufffler to rip off! I just want it low enough to give it a nice low stance and not be too bouncy.
Old Mar 19, 2007 | 01:08 PM
Mahjik's Avatar
Mr. Links
Take a look at the Tein Flex. You an also add the EDFC to have damper adjustibility inside the cockpit rather than having to go to each shock for adjustment.
Old Mar 19, 2007 | 01:29 PM
aznpoopy's Avatar
strike up the paean
i've sat in a car with flex's. surprisingly comfy. not a bad option.
k-sport ride quality is crap, which is not too surprising. definitely don't go that route. i have not ever sat in a car with megans.
