Power FC bugging when hitting throttle
Old Mar 14, 2007 | 04:48 PM
puma's Avatar
canadian monster
ok, here is the situation, new engine, complete new setup, single, fuel, ported engine, etc...
i inserted the map of a friend who has a similar setup and want to run that setup until i get it tuned by steve kan. The only thing that seems to be working weird with the car is when i try to move the car, if i don't rev it first, the car wants to die, you know, like when you just hit the gas at idle and it's just choking. Well i just said, this is an easy fix, i just need to tweak the acceleration enrichment but no matter what value i put in, it doesn't change anything.
the current setup at 1000 rpm (the only place where i have a problem) is 7,4 ms and 2 ms.
i have tried as low as 4 and as high as 9 and i still had the same thing happening. Should i try to tweak the map? Should i put more or less fuel? Anything else i should try? Only tried with the commander so far.
thanks a lot for any input, i am still learning and really want to try things with the datalogit.
R.O.D
34
Jan 6, 2016 12:09 AM
matty
47
Oct 4, 2015 02:45 PM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
teebeekay
Sep 16, 2015 01:54 PM
rx7shirley
Sep 2, 2015 02:11 PM
