265 on the front of my FD
Old Mar 4, 2007 | 01:27 PM
Komodo1982's Avatar
7-Style
ok I ALREADY KNOW ABOUT THE SIZING THREAD!! I CANT open it because my Excel is messed up. I need to know if 265/35/18 will fit on the front of my fd with a 9in rim and a +42 offset?
Thanks Ken
Old Mar 4, 2007 | 01:34 PM
ptrhahn's Avatar
Ken,
it'll be tight, but not impossible. I run a 255/35 on the same rim.... it will rub the liner at full lock a little, and you'll want rolled fenders.
Old Mar 4, 2007 | 03:49 PM
Komodo1982's Avatar
7-Style
do you rub with your 255?
Old Mar 4, 2007 | 09:48 PM
1st to 3rd's Avatar
I run a 255 on a 9" +42. It is a pretty good fit, but you'll eventually catch the fender lip pulling into a steep driveway, et al. It's always a good idea to roll the front fenders.
Like ptrhahn said, a 265 can be made to work, but it will be tight on that wheel/offset. Aside from being wider, it's also a little taller then stock.
Old Mar 4, 2007 | 10:00 PM
ptrhahn's Avatar
It rubs the liner in front, behind the washer bottles when the wheels are turned at full lock, but honesly, most all aftermarket wheels do.
Old Mar 4, 2007 | 10:07 PM
Komodo1982's Avatar
7-Style
ok well then i guess im not gonna go with the khumo MX then since they jusp from 245 to 265, back to the drawing board
mazdaverx713b
19
Aug 29, 2015 12:30 PM
