Master Cylinder Upgrade
Old Mar 3, 2007 | 07:36 PM
Jesuscookies's Avatar
I can haz rotary?
Okay I have recently upgraded to 12" discs up front and 11" discs out back. Obviously alot of braking power compared to the stock RX2. I need to find a suitable upgrade for the Master Cylinder. Any suggestions?
For size reference, I need at least 15/16, 1" would be better.
I was thinking maybe an FD MC would work?
Anyone have any experience or advice they can offer?
Old Mar 3, 2007 | 08:02 PM
RotorRican's Avatar
Rotary Loco
Sorry, no advice!
am following you guys steps on my build up. am getting the front kit from Tony at the racing store . I got a Ford 8.8 rear with disk brakes, so i will need to find out what master cylinder will work also!
Andres
Old Mar 3, 2007 | 08:19 PM
Siraniko's Avatar
RX for fun
FD may not work as the brake lines need to go on each side (left and right side). It may not clear the strut tower ====>>>>I dont RECOMMEND a BFH solution.
Old Mar 3, 2007 | 08:26 PM
13B-RX3's Avatar
7s before paint!!!
I used a late model Chrysler MC on mine. It is the areospace 2 piston on the front and wilwood 4 piston out back. That is the MC most pro stock type cars use.
Old Mar 3, 2007 | 08:41 PM
I can haz rotary?
Was it straight bolt on, or did you need an adapter plate? what year and model did you use?
Com'on, more details!
Old Mar 3, 2007 | 08:52 PM
13B-RX3's Avatar
7s before paint!!!
Dammit man, do i have to do all the work for you . I made an adapter out of a piece of 3/4 aluminum, i bolted it to where the booster originally went.
I will look and see if i can find the exact part # i used.
Old Mar 3, 2007 | 09:01 PM
I can haz rotary?
I am assuming I can use it with a booster no problem. And thanks for doing all the work for me.
Old Mar 4, 2007 | 12:49 AM
13btnos's Avatar
$90.00 not bad of a price http://www.theracingstore.com/index....mart&Itemid=26
Old Mar 5, 2007 | 04:06 PM
I can haz rotary?
Take a closer look at the pic. It looks like the lines are coming out on the same side as the shock tower. Already a close fit without that issue. Also, I talked to Tony, and he did not recommend this MC for the swap I was doing.
Originally Posted by 13btnos
Old Mar 5, 2007 | 04:13 PM
13B-RX3's Avatar
7s before paint!!!
Go with what Tony says!!! He would know.
What did he recommend?
Old Mar 5, 2007 | 05:28 PM
I can haz rotary?
Get me that chrysler part # you retard.
Old Mar 5, 2007 | 07:36 PM
Bacon's Avatar
IRS 4 Life
A lot of us FD guys upped to the 929 master cylinder, and both ports face away from shock tower, and size requirements should be what your looking for
1" bore also, some more pics in the link.
http://www.rx7.org/Robinette/mastercylinder929.htm
Old Mar 6, 2007 | 02:54 PM
I can haz rotary?
This is the MC I wanted to use, but I was concerned about the adaptability. In any event, I picked up 1 for a good price, so I will give it a go. Hopefully, I can get it to work without too much trouble.
Old Mar 6, 2007 | 04:04 PM
13B-RX3's Avatar
7s before paint!!!
Stop whining and put it on. It is just the brakes.
Old Mar 6, 2007 | 04:58 PM
I can haz rotary?
Lol, give me my part number homo!
Old Mar 6, 2007 | 09:22 PM
13B-RX3's Avatar
7s before paint!!!
http://www.napaonline.com/masterpage...Cylinder+-+New
Let me know if there is anything else i can do for you.
Old Mar 6, 2007 | 10:21 PM
I can haz rotary?
Thanks Allen, you're the best!!!!
Old Jan 22, 2009 | 11:09 PM
Smeagol's Avatar
Hey Jesus,
How did this work out? I want to do something similar on my RX-2's. I'm getting tired of the remote reservoir leaking all the time.
thanks,
Mike
Old Jan 23, 2009 | 12:22 AM
sim_rx3's Avatar
just so you know guys.
Nissan Patrol 4wd GQ
well thats what we call them in aus
master cylinder bolts on and is 1" bore
pic -
Old Jan 23, 2009 | 09:47 AM
EDSRX3's Avatar
Don't know about the RX2, but this is the MC I used for my RX3.
I have the areospace 4 piston brakes upfront and RX7 disks on the back.
I could not find a MC to work with a booster in the small space for the RX3.
This MC is for a late 70's ford 4 wheel disk non-power brake application. The bore is 1 1/16 inch. Picked it up from Lordco. Wish I could tell you the specifc car, I'd have to dig through my box of recipts to find the Lordco part#.
I had to make an addapter plate to match the 3 bolt pattern on the firewall to the 2 bolt pattern on the MC, and modify the push rod to match up to the brake pedal.
I have not run this set up so I'm still hoping it will work ok, but with all the brakes I have at the wheels it should be just fine!
Old Jan 23, 2009 | 09:19 PM
I can haz rotary?
This truck was not available in the US, and unfortunately the lines are on the wrong side. It will hit the strut tower.
pic -
Old Jan 23, 2009 | 09:20 PM
I can haz rotary?
Can you get us a part number or the car it came of off? It looks like an easy retrofit.
Old Jan 23, 2009 | 11:55 PM
Siraniko's Avatar
RX for fun
Just use a mazda GLC RWD or a FB MC. Its that simple. I have tried each one with no issues. they both work well in my RX-3's with rear disk brake conversion and FB front brakes.
Old Jan 24, 2009 | 11:55 AM
I can haz rotary?
The FB MC does work. It is what I am currently using. But with big discs front and back, a 1" or 1 1/16" would have a little better pedal action. The FB is only 15/16 I believe.
Old Jan 25, 2009 | 07:25 PM
Smeagol's Avatar
Is the GLC MC bigger, wacky? If so, what years are the same thread pitch, 77-79? Hmm, according to rockauto they're both 13/16" bore for 79 RX7 & GLC so maybe they're the same part.
I always thought the 81-85 FBs had the finer thread pitch so they wouldn't directly swap in. I guess you could always change/flare the ends to the correct pitch but is there any real benefit? I think those are 13/16" bore also.
Mike
