offset question
Old Feb 13, 2007 | 12:07 AM
eff_three_see_es's Avatar
lycanthrope
offset question
higher offset=further away from car?
Old Feb 13, 2007 | 12:21 AM
masao's Avatar
I am the Autoholic
Opposite, iirc.
Old Feb 13, 2007 | 12:25 AM
misterstyx69's Avatar
Retired Moderator, RIP
Nope..if the Stock wheels are 40mm offset,the Face of the wheel is basically at the End of the outer edge of the Wheel(40 mm in),Towards the street.So if you add more offset,the wheel goes Outwards.
lycanthrope
iirc?
Old Feb 13, 2007 | 12:26 AM
IF I recall correctly.
Old Feb 13, 2007 | 12:31 AM
lycanthrope
so say that a stock rim is 40 offset. a 25 offset would be a "deepdish" wheel?
Old Feb 13, 2007 | 12:36 AM
metal's Avatar
Sewww Speciellllllll
25 offset would usually have some dish, since it'd push the edge of the wheel further out.
Old Feb 13, 2007 | 12:37 AM
TehMonkay's Avatar
Back in the game
40 mm is stock
10 mm would have the tire sticking out of the fender
get the picture?
There are so many freaking articles stickies threads faqs etc on the internet about wheels and tires.
Old Feb 13, 2007 | 12:41 AM
finishline's Avatar
Not Even Foo
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Feb 13, 2007 | 12:50 AM
lycanthrope
good lookin out guys
Old Feb 13, 2007 | 05:57 PM
NCross's Avatar
I have a rotary addiction
Im running 15x7 +8 and its flush in the front and could use a set of -5ish offset in the back to make them flush.
offset is how far away the mounting position is from the center of the wheel. positive offset means that the mounting spot (where it mouts against the hub) is that far towards the car, negative means its away from the car.
_Tones_
May 25, 2021 05:37 AM
