wheel fitment on advans.
Old Feb 2, 2007 | 04:01 PM
catch-22's Avatar
i found some advan rims and the offset on them is 31 and i need to know if this will fit on my fd. the rim size on the advans are 16 x 8 same as stock. how will this offset make the rim fit further in or outfrom the stock rim location? thanks
Old Feb 2, 2007 | 04:09 PM
Mahjik's Avatar
Mr. Links
Stock rims are 16x8 at +50. The larger the positive number, the more it goes INTO the car. So, a +31 will move the wheel OUTSIDE the car more.
What is your current and/or planned suspension setup?
Old Feb 2, 2007 | 07:57 PM
rynberg's Avatar
It will move the wheel over 3/4" out toward the fender. Rub city on anything but stock suspension or rolled fenders. Not to mention how much you are messing up the scrub radius.
Old Feb 3, 2007 | 10:47 AM
catch-22's Avatar
yeah the car is on h&r springs with stock shocks. so these will rubs like crazy with that setup
Old Feb 4, 2007 | 02:40 PM
Mahjik's Avatar
Mr. Links
H&R spring are pretty low. In the least, you would need to roll your fenders. However, I think you would run into issues with the H&R springs and those offsets. With coilovers, you might be able to make it work.
Old Feb 6, 2007 | 07:47 PM
catch-22's Avatar
k thanks alot
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
