Will these wheels fit my FC?
Old Jan 27, 2007 | 11:45 AM
MmSadda's Avatar
Can someone tell me if these wheels will fit on my FC?
https://www.rx7club.com/showthread.php?t=613838
Old Jan 27, 2007 | 12:49 PM
Jaiyurai's Avatar
Endure Persevere Succeed
yes.
Old Jan 27, 2007 | 02:07 PM
Black91n/a's Avatar
You're likely to get some rubbing on the suspension with those, so a small spacer might be needed in the front. The rears should clear no problem.
Old Jan 29, 2007 | 02:38 PM
MmSadda's Avatar
Jaiyurai, how sure are you that they'll fit (without rubbing)?
Black91n/a, How did you come to the conclusion that they will probably rub? How large of a spacer would I want? Where could I find it? and how much would it cost?
Thanks, guys! Any further input would be greatly appreciated!
Old Jan 29, 2007 | 02:45 PM
RotaryEvolution's Avatar
Sharp Claws
they probably would rub in front unless you went with a smaller tire in the front like a 215 or 205, spacer size to fit those would be minimal, like 3MM or so.
Old Jan 29, 2007 | 06:49 PM
Black91n/a's Avatar
WEll 225's on 17x8's with a 35mm offset barely fit, so these might fit, they might rub. If they do run it'll only need a thin spacer, but to get the most clearance possible on both sides, a 30mm offset is about ideal.
Old Jan 30, 2007 | 11:44 PM
MmSadda's Avatar
Okay, let's say theoretically I was to add a 8mm spacer to the front wheels. That's the smallest spacer I can find. That would change the offset to 30, correct?
Would I need to worry about a widebody kit at that point?
(I'm just trying to find some decent wheels to throw on a n/a s4, not looking for a big project)
Old Jan 31, 2007 | 12:03 AM
Black91n/a's Avatar
Yea, 38mm offset + 8mm spacer = 30mm offset. That's about a perfect offset for fitting wide tires up front, no need for wider fenders or even fender rolling.
Old Jan 31, 2007 | 12:07 AM
Sharp Claws
added to post below V
Old Jan 31, 2007 | 12:09 AM
Sharp Claws
i have 17X8 +35 with 225's in front and they tuck perfectly with an 8mm spacer, with +38 yours would be out 3 more mm than mine but mine is dropped 2" in front.
you will probably have to roll the fenders a little with an 8mm spacer and 225's unless you have stock height as it may not rub until you corner hard.
Old Jan 31, 2007 | 07:09 PM
Black91n/a's Avatar
I'm running (nearly) stock suspension, 17x8, 30mm offset, 225/45/17's. No rubbing ever, not even at the track or at autocross.
fidelity101
13
Aug 31, 2015 07:47 PM
