Medium Weight Aftermarket Flywheel
Old Mar 14, 2002 | 08:43 AM
Kurgan's Avatar
Gaijin Racing
I'm looking for a medium weight (somewhere in the 13-17 lb range) flywheel for a series 5, 1989-91 T2. Does anyone have any suggestions on such a beast? Anyone running something like this that may have some feedback?
Thanks in advance!
Old Mar 14, 2002 | 10:18 AM
rxrotary2_7's Avatar
Custom signatures are enabled, but any graphics used in such signatures are limited to a 20K file size.
Signatures should be less than 460x200 in size, or no more than 10 lines of text. Combination image/text signatures should have no more than 5 lines of text.
There is currently no system to automatically check for these limits, so Admins and Moderators will be checking manually. Should your sig be found in violation, it will be removed without warning. It is your responsibility to then edit the sig and bring it within compliance. If you don't know how to edit an image and bring it under the 20K or 460x200 limit, don't use it! Figure out how to edit the image first or it will be removed.
Old Mar 14, 2002 | 10:24 AM
what will the car be used for? drag? autoX daily driver....this type of info is needed for member to help answer your question better.
Old Mar 14, 2002 | 11:00 AM
Kurgan's Avatar
Gaijin Racing
Thanks for the practically worthless information that should have been sent via PM. Never had a complaint before, but I've complied. I've fixed the image size for now, but don't really have a place to host it for the next 8 hours, so I'm using the rx7forum to host it until then... when I get home, I'll put it on my own server.
No, that info is not needed, I just wanted to know if anyone knew of a good medium weight flywheel. I know what the advantages and disadvantages are for changing flywheel weight, I've decided on this.
But, for the record, it is going into my 20B T2 with a T-76 turbo, daily driver... mostly for straight line, will do some drag racing... maybe, and I say MAYBE, some road racing... but no autocrossing.
Old Mar 14, 2002 | 11:51 AM
if you have decided on it, then you must have already gotten some feedback or have enough knowledge to not have to ask that question. that is the reason i asked you to please help us help you with your choice. and now that you state what you have "under the hood", i think that is a little different than what you previously said you were putting it into.
how should i or anyone else know that is what you are running by your original post if we are not familiar with you or your car? by checking out your webpage? sorry i didnt do that first. dont be a dick.
Old Mar 14, 2002 | 12:08 PM
Kurgan's Avatar
Gaijin Racing
I wasn't being a dick... I just think that stuff like your first reply would be better directed personally than in the forum... Just delete this thread, no one is going to respond now anyhow...
Old Mar 14, 2002 | 12:14 PM
87GTR's Avatar
rxrotary2_7 you got sand in **** today?
Old Mar 14, 2002 | 12:54 PM
yeah i must
Old Mar 14, 2002 | 03:21 PM
twister's Avatar
I use a lighweight flywheel - abour 10lbs from guru motorsports in Australia. I run it in a circuit car but some guys also use it on drag cars over here.
Cheers,
www.gurumotorsports.com
Old Mar 14, 2002 | 03:43 PM
Kurgan's Avatar
Gaijin Racing
Cheers,
Cool thats good to hear. I may be ordering their set of dog gears for my S5 gearbox, so i may order that flywheel at the same time...
THANK!
Old Mar 15, 2002 | 12:16 AM
crispeed's Avatar
'Tuna'
I've found the Racing Beat 17lb light weight steel flywheel to be the best setup for a daily driver.
crispeed
87 Rx-7 TII
9.20@150mph
2600lbs
Old Mar 15, 2002 | 12:36 AM
Kurgan's Avatar
Gaijin Racing
crispeed
87 Rx-7 TII
9.20@150mph
2600lbs
The BIG DOG speaks and we listen!!!! Thanks Cris!
hehehehe
George84
Sep 28, 2015 11:58 PM
risingsunroof82
Sep 9, 2015 08:06 PM
Enzo1944
Sep 6, 2015 08:57 AM
