FD - Will it rub 295/35/18
Old Jan 12, 2007 | 11:19 AM
crxturboh22's Avatar
will it rub 295/35/18
I need to know asap if that will rub i'm getting a good deal so let me know thanks
asap..
i was running 275 before, no problems..
18x 9.5 35 ofset i believe
any 1
thanks
Old Jan 12, 2007 | 12:54 PM
ptrhahn's Avatar
You'll probably want a 293/30, not a 295/35...
That's really too much tire for a 9.5" wheel (i'd want at least 10.5"), and you may find that a fender roll is necessary if you DO try it. Check the tire manufacturer's specs to make sure that isn't below the recommeded range for wheel width for that tire. I suspect it is.
Old Jan 12, 2007 | 01:34 PM
damn.. i did a search and from what i understood some people are.. but damn i need tires.. thanks
Old Jan 12, 2007 | 02:13 PM
c'mon guys i jst need to know if it will work .. will it run fine... not rubbin ? i got tein's springs. wasup..
Old Jan 12, 2007 | 03:54 PM
ptrhahn's Avatar
I just told you:
295/35/18 is too tall... 26.1" diameter.
295/30/18 are the proper diameter, but are too wide for your rim. 295/30/18 require at 10" rim at the MINIMUM, and really ought to be on a 10.5 or 11".
275/35/18 is what you should be running. Daswassup.
Old Jan 12, 2007 | 04:09 PM
wanklin's Avatar
Rob
lol^
yeah boyee, If you do this you will:
1) bottom out unless you raise the car
2) throw your speedo and ABS off
3) stress your tires and they'll look like dunkn doughnuts
4) most likely rub when the rear squats, due to the low offset
Old Jan 12, 2007 | 08:37 PM
okay so i ended up going with 285/30/18
no problemo
I'll be posting pics of the wheels soon
hopefully by later tonight or tomorrow morning latest.
c0rpse
16
Sep 25, 2015 11:33 AM
