TII air flow meter question
Old Jan 8, 2007 | 08:09 PM
rotary-guy's Avatar
2jz'd fc
hey i was wondering if a S5 NA afm would work on a S5 TII?
Old Jan 9, 2007 | 07:44 AM
asiandude15's Avatar
I was reading for a S4 that they said the N/A works for a TII but the TII AFM is set to a high air flow. I'd imagine it would be the same for a S5.... Not 100 percent sure though....
Old Jan 9, 2007 | 12:41 PM
seventh_rx's Avatar
Memento Mori
no, springs are different.
Old Jan 9, 2007 | 10:35 PM
woundup7's Avatar
The Outsider
Yes it works, because I have been using one for the last three months. My N-370 went out, so I put on a N-350. BUT I ALSO HAD A S-AFC and A WIDEBAND TO FATTEN UP THE FUEL CURVE. DO not use one without some way to rich up the ratio a lot, I went from - 10 at 6000rpm to + 20 at the 6000rpm just to retain the same afr at 6000 rpm. You will detonate and most likely pop your motor without adding alot more fuel.
BTW I have a S-aFC for sale. PM for details
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
Snoopy FD
Dec 8, 2015 01:45 PM
12abridgeport
Aug 17, 2015 06:28 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
