RX3 Project car progress report
Old Dec 27, 2006 | 11:24 AM
EDSRX3's Avatar
Work has started on the project.
I completed the conversion of the dif. LSD and Disk brake conversion installed, New shocks and the leaf springs re-arched and an extra leaf added.
Now I've pulled everything out of the engine bay and dashboard to prep for paint.
Looks like I've lined up all front end components except the pitman arm and I only found a rebushing kit for the idler arm.
Attached Thumbnails RX3 Project car progress report-img_0044.jpg   RX3 Project car progress report-img_0046.jpg   RX3 Project car progress report-img_0041.jpg   RX3 Project car progress report-img_0043.jpg   RX3 Project car progress report-img_0042.jpg
Old Dec 27, 2006 | 11:32 AM
banzaitoyota's Avatar
What Subscription?
Very nice
Old Mar 12, 2007 | 10:00 AM
EDSRX3's Avatar
More work done! Paint in the engine bay completed! New tierod ends and ball joints. Koni reds in the struts, all new front bushings! New master clutch cylinder.
Hopefully everything bolted on will be on will be new or renewed!
Attached Thumbnails RX3 Project car progress report-3rdpicture-003.jpg   RX3 Project car progress report-3rdpicture-004.jpg   RX3 Project car progress report-3rdpicture-006.jpg
Old Mar 12, 2007 | 11:44 AM
Doc Holiday's Avatar
Needs more cow bell
Nice.
Old Mar 12, 2007 | 08:24 PM
AMTGoofy's Avatar
Awesome color.
Old Jan 3, 2008 | 09:57 AM
EDSRX3's Avatar
Progress Jan 08
more progress on the car.
Tires, wheels all around, 4 piston caliper brakes up front. Replaced all the brake hard lines and installed stainless flex lines and changed the vacuume booster/ Master cylinder to a big bore manual brake master.
12a and tranny in the engine bay for mock up.
Undercarage cleaned and recoated, original heat sheild ready to install for the exhaust build.
Front sheet metal back on the car!
I've cut open the wiring harness to remove the old unused wires. Now I need to select an altenator, ignition system and guages etc. to complete the wiring.
Attached Thumbnails RX3 Project car progress report-xmas07-113.jpg   RX3 Project car progress report-xmas07-115.jpg   RX3 Project car progress report-xmas07-117.jpg   RX3 Project car progress report-xmas07-109.jpg   RX3 Project car progress report-xmas07-114.jpg
Old Jan 3, 2008 | 11:37 AM
teddyrx2's Avatar
One Luv "Till The End"
looks good
Old Jan 3, 2008 | 03:07 PM
Judge Ito's Avatar
sweet
Old Mar 17, 2010 | 09:46 AM
EDSRX3's Avatar
Just about finished
A lot of progress made.
½ bridge 12a with a RX3 intake and modded nikki with carter fuel pump. 2" dual exhaust to 3" over the dif and out a magnaflow. 4-puck clutch, direct fire with MSD box. rebuilt original rad with stock plastic rad and under engine shroud. Lots of new gauges, duel exhaust temp, oil temp/pressure, coolant temp.
A few details left, new light bulbs all around, connecting up the gauge dash lights, installing the cables to the carb and putting all the fluids back in the car. Biggest expense left is a new drive shaft( mock up currently in-place).
Fire it up, set the timing, wash everything.
Drive it for a while and shake out issues, then strip it all down again for paint!
Old Mar 17, 2010 | 09:55 AM
EDSRX3's Avatar
and here are the pics
Duh!
Attached Thumbnails RX3 Project car progress report-rx3-near-end-mar-2010-001.jpg   RX3 Project car progress report-rx3-near-end-mar-2010-003.jpg   RX3 Project car progress report-rx3-near-end-mar-2010-005.jpg
Old Mar 17, 2010 | 12:12 PM
datfast1's Avatar
Nice!!!
auggie463
21
Sep 2, 2015 01:46 PM
cam_7779
Aug 18, 2015 07:48 AM
ashleymiche
Aug 14, 2015 12:59 PM
