Optima Battery Choices?
Old Mar 9, 2002 | 07:55 AM
Gefunk's Avatar
Ok everyone, I need help once again, go figure. Well I am currently on the summit racing site looking at optima batteries. If any of you have any other online distributers I would like to compare prices. However, the real question is what "style" battery I should get? There are three choices on the summit site: a high power out put 870 amp one, a 750 amp one, and a 12.8V 750 amp one. I am just wondering witch one to purchase. Thanks for the info guys and if any, girls
Old Mar 9, 2002 | 09:55 AM
Max7's Avatar
Admitted Sevenaholic
Red top (Standard) for most people
Yellow top (Deep cycle) if you have a big stereo AND listen to it alot with the car off.
Old Mar 9, 2002 | 10:41 AM
Aaron Cake's Avatar
Engine, Not Motor
I have the red top (1050CCA). Remember: a standared alternator will NOT charge the deep-cycle yellow top correctly. Deep cycle AGM batteries need a special charging cycle.
Old Mar 9, 2002 | 02:40 PM
Gefunk's Avatar
Ummm...where did you guys get your batteries? A local shop or online? If online what did you pay and where? Hahaha, thanks for all the help guys
Old Mar 9, 2002 | 03:22 PM
Aaron Cake's Avatar
Engine, Not Motor
Got mine from a local speed shop for 175 Canadian. Buying batteries online is not cheap because of the VERY heavy shipping...
Old Mar 9, 2002 | 05:39 PM
KNONFS's Avatar
B O R I C U A
Red top is all you need!
Old Mar 9, 2002 | 05:42 PM
boostmotorsport's Avatar
Ive got a yellow top behind my driver seat to acomidate IC piping, and havebt had any probs
Old Mar 9, 2002 | 06:40 PM
rx7passion's Avatar
standard alternator wont charge it?? i have a yellow top that i snagged for free and ran it in my first gen for a while still have it in there never had any charging problems. also i threw it in a ford ranger for about 4 months never encounted any problems. could you elaborate i dont really want to fark it up since its worth close to 200$
Old Mar 9, 2002 | 08:18 PM
KNONFS's Avatar
B O R I C U A
It will work just fine, there are rumors (probably true) that deep cycle batteries will create a memory, which equals to shorten life.
Old Mar 9, 2002 | 08:25 PM
Aaron Cake's Avatar
Engine, Not Motor
I said won't charge it correctly. Basically, you will see reduced battery life and capacity.
Deep cycle AGM batteries do not have the memory effect. Period. No lead acid battery does. Only NiCad batteries used to exhibit memory, but the formula has been refined to the point where memory effect in modern NiCads is very rare.
renjiv2
57
Jan 25, 2024 03:34 AM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
