Rotary Drag Racing The place to post your racing stories and info
Launch Bog
Old Dec 12, 2006 | 07:15 AM
PBK7's Avatar
Launch Bog
I'm trying to decipher wher i'm going wrong at launch:
At 5K easing off the clutch( minimum wheel spin) the car accelerates okay.
At 6.5K dropping the clutch and redlining the gear change after all the wheel spin/hop the 2nd gear falls absolutely FLAT. Almost as though the ecu is in some failsafe mode. This will last almost forever, meaning that the RPMS climb very lazily unless i neutralise and relaunch.
Car Stats:
93r1
street port
Redom ECU
ACT street/strip clutch
FPR
Xs Power SMIC
Old Dec 19, 2006 | 12:14 PM
MichaelB145's Avatar
www.mancavecolorado.com
I launch at much higher RPM's (7K or so) but I wouldn't if I were you unless you have Kaaz rear end and some good slicks.
Old Dec 19, 2006 | 02:56 PM
PBK7's Avatar
Okay, but ever experience the ecu falling flat?
Old Dec 19, 2006 | 03:18 PM
I guess I don't know what an "ecu falling flat" is.......It sounds like you are just bogging the launch which will drop the rpm's below 4K which will kill your power.
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
