Thread Tools Search this Thread Display Modes
Old 12-12-06, 03:06 AM   #1
89-gtu-rx
gtu89
Send a message via AIM to 89-gtu-rx
headlight control arm help
could i shorten the control arm from the power light motor to the light to make pop up about 2 inchs
89-gtu-rx is offline   Reply With Quote
Old 12-12-06, 03:16 AM   #2
anderdick88
SURE u can just cut it
anderdick88 is offline   Reply With Quote
Old 12-12-06, 03:41 AM   #3
micah
Winter sucks
micah's Avatar
Send a message via AIM to micah
Yeah, but thats non-reversible! But.. if thats what you want. go fer it.
micah is offline   Reply With Quote
Old 12-12-06, 03:42 AM   #4
micah
Winter sucks
micah's Avatar
Okay, I just went out and looked at it... Instead of cutting it, just remove it, and drill another hole in it for the push-rod ball joint to connect to... that way you can put it back to stock if you ever sell it or what not.
Just my 2cents.
Old 12-13-06, 12:54 PM   #5
need-a-t2
the machinest
need-a-t2's Avatar
Send a message via AIM to need-a-t2
it's not quite as easy as just drilling one hole. You need to move the pivot point of the motor arm closer to the motor, and then you also need to lengthen the linkage arm that goes from the headlight assembly to the motor linkage. That will give you a shorter throw with faster pop-up speed.
need-a-t2 is offline   Reply With Quote
Old 12-13-06, 12:57 PM   #6
need-a-t2
the machinest
need-a-t2's Avatar
it will also reduce the torque on the headlight assy, so a nice layer of ice may cause you some issues with opening your headlights.
Old 12-13-06, 01:08 PM   #7
classicauto
Crash Auto?Fix Auto.
classicauto's Avatar
search "sleepy eye" or "sleepy eye mod"
__________
or try "useless ricer mod" or "mad tyte dorifto hedalight"
The only way to apex a corner is with apex seals under the hood!!
"These four wheels feel like home to me.......they breathe" - Flatliners, This Respirator
classicauto is offline   Reply With Quote
Old 12-13-06, 05:01 PM   #8
micah
Winter sucks
micah's Avatar
Thats exactly what drilling another hole would do.... Keep in mind. I meant drilling another hole in the ARM.. not the linkage.
Old 12-13-06, 05:32 PM   #9
dwb87
GXL/TII
dwb87's Avatar
Send a message via MSN to dwb87
I've tried something similar... and it almost fucked up my light. You need to do more than just drill a whole. The rod is pushed up by the motor and the motor pushes and pulls the exact distance the light needs to go up or down. If you shorten the rod or drill another hole in the rod the motor will get stuck when pulling the light closed because it can no longer pull down the distance that it did... atleast that's what happend to me. Just look at it.
dwb87 is offline   Reply With Quote
Old 12-13-06, 06:27 PM   #10
need-a-t2
the machinest
need-a-t2's Avatar
bingo...that's why you need to lengthen the linkage arm as well.
Old 12-13-06, 09:14 PM   #11
micah
Winter sucks
micah's Avatar
ahh.. that makes sense.. My bad.. You right me wrong.
Old 12-13-06, 09:35 PM   #12
dwb87
GXL/TII
dwb87's Avatar
It's alright... I thought the same thing and actually tried it. Didn't work.
Search this Thread:
Advanced Search
HTML code is On
Top
