Some Ideas Please!
Some Ideas Please!
i just traded my bike for a 1990 rx-7. its really clean from inside to out. a midnight blue exterior and the inside is in perfect condition. only 83k on the motor. ive got about 2500 i can spend on the car but i have no idea what to do. any suggestion?
Well, the catback would be first for the quest for more power. A midpipe would be next if you can get around emissions and don't mind noise. You would also want to get a intake of some kind. I wouldn't do anything else till you got those things installed and get a feel for the car. Don't spend it till you KNOW what you want.
Trending Topics
suspension, its all u need to drift. since u have 2500 u can probably get some really nice coilovers but then ur broke. u could rebuild the engine n build it up too. there's so many ways to go about this. if i were u i'd make sure it can run for a while, probably save some money up and then get some suspension n then add to the power of the car.
First, get is safetied and see what it "needs". Next, exhaust and tuning from someone knowledgeable with the car (making sure acturators work, etc etc). Finally, tires or rims if anything is left over.
take your 2500 and buy a 240sx. easiest car ever to drift. i still cant get over it..
option 2 - put a 5.0 in it. theres a guy in san antonio that did it with no money out of pocket. cheap cheap power to break the tires loose.
the 240 is under powered n to swap an sr in it is 4k if u go to a good place, like unnatural inc in beaverton and they have weak front tire grip so understeer is a huge problem. i have a buncha frieds with 240's n they understeer like mad, u gotta upgrade the 240 suspension so u dont understeer. besides, fc's own.
FC-1, back [in some black]
...Dude - he's got an S5, it has *plenty* of power to break loose :P
[besides why waste such a great engine as an S5 NA..]
like everyone else is saying: do all the fluids and filters [oil change, fuel filter, coolant flush, etc] and drive it for a few months to make sure there are no problems with it
The car should handle pretty well right now, but get new suspension installed to bring it back to life.
I'm also told that a strut bar [like say for the engine compartment], will help it handle better.
Also consider this: are you going to daily drive the car? In that case you probably don't want to go too far on power mods [especially permanent changes such as porting], so you don't crush your fuel economy..
Oh and after all of that.. go pick up a couple of wheels so you can quickly switch between driving/drifting tires.. [should be cheap.. stock 16" wheels are reasonably priced]
well i want a good street racing car and autocrossing... want somewhere around 250-300 hp. so that i can go to those night races and smash on cars taht think they are fast. also i wanna take this bad boy autocrossing. this is also gonna be my daily driver...
you plan doning these things on a DD:
drifting
autocross
street racing
and 250-300hp
on 2500
im sorry dude but this is just looking like a good way to break you car and have some expensive problems with no way to get around.
not to flame you but i dont think your looking at this correctly.
first and foremost, make sure it can be daily driven n then do exactly that for a lil while. then suspension cause power is not important, thats right NOT IMPORTANT! just look at the guys in D1 with hachi's with less than 200hp, all driver skill n suspension. suspension n chasis stiffness are pretty much the best way to go for handleing and drifting
