Sponsored by: CARiD
re vs rew rotors
Old Dec 6, 2006 | 06:47 PM
slo's Avatar
slo
registered user
re vs rew rotors
Is there a difference between re and rew rotors?
I know that the s5 t2 and rew rotors are the same weight and comp. But my understanding is that the rew rotors are hardened at the apex seal groove.
Is that correct?
Are the re rotors identicle to the rew rotors?
Old Dec 6, 2006 | 08:26 PM
dizflyaznboi's Avatar
13bt REW is the FD engine, it is also twin turboed. Im guessing RE is just a 13BT
Old Dec 6, 2006 | 08:30 PM
Brody8877's Avatar
#FakeCarEnthusaist
Correction 13BRE is the cosmo engine and the REW is the FD
Old Dec 6, 2006 | 08:37 PM
RETed's Avatar
It's all basically the same.
The 13B-REW rotor is supposed to run a deeper rotor bearing groove.
The weights and compression are all the same.
The machining tolerance is supposed to be tighter for the 13B-REW rotor (i.e. machined tubs and faces), but there's a lot of inconsistences with Mazda production on this one.
-Ted
Old Dec 7, 2006 | 12:10 AM
RotaryResurrection's Avatar
From my observation all post-FC turbo rotaries have identical rotors.
Old Dec 7, 2006 | 01:07 AM
GtoRx7's Avatar
Collections Hold
Is that correct?
The REW rotors are hardened on the apex seal tips. They also have been factory clearanced on the sides of the faces. The casting however on the inside is even worse than the S5 rotors and RE rotors (same thing, as you have found.)
Ian_D
Oct 14, 2015 12:31 PM
ZacMan
Sep 19, 2015 09:20 PM
Ian_D
Sep 6, 2015 10:38 PM
