Help ! ! !
Old Mar 8, 2002 | 10:01 AM
RAZZOR's Avatar
Help ! ! !
Have just bought a 93 R1 with a problem.
As soon as it boosts it starts to break down.
if i switch the ignition off /on it will boost to .5 bar and starts breaking down again.
Have replaced all the vacum hoses but problem still there.
Any ideas ? ? ? ?
Q. where is the check engine light located .
Old Mar 8, 2002 | 10:04 AM
P'cola FD's Avatar
Hamado things my way!
What do you mean it starts to break down? Does the car shut off, or bog severely? Have you checked your MAP sensor hose?
Old Mar 8, 2002 | 10:51 AM
RAZZOR's Avatar
The car bogs badly just as it starts to boost.
I can drive of boost with no problem ,but as soon as it gets to 0 on the boost gauge it starts spluttering and backfiring.
Old Mar 8, 2002 | 10:59 AM
Bucrx7's Avatar
First thing's first, change your plugs and wires.
Old Mar 8, 2002 | 11:06 AM
Rated R1's Avatar
Oji San
I agree. Check this first!
Old Mar 8, 2002 | 01:59 PM
SanJoRX7's Avatar
uid 0
If you don't know when the fuel filter was last changed, think about doing that, same with the air filter. Do you have a DP or the stock precat? If it's the latter, might be clogged and the backpressure is significant enough to cause bogging.
Old Mar 8, 2002 | 08:02 PM
rynberg's Avatar
you might be in "limp home" mode
reset the ecu: pull the neg batt cable, step on brake for like 30 seconds, reattach batt cable, start car, drive, hopefully it works
