Power FC my car stalls when i tap my power FC
Old Dec 4, 2006 | 01:23 AM
f150rx7's Avatar
I noticed my car wants todie out for a second everytime i close the passenger door, so i check whats obvious first and i was right, i tap the power fc with my fingers and the car stalls but can start right up again, anybody experience this before?
Old Dec 4, 2006 | 08:58 AM
DaleClark's Avatar
RX-7 Bad Ass
That's way out of the ordinary. Time to look at the wiring - you may have a bare wire shorting against something.
The PFC's have proven to be quite hardy, so I'd moreso suspect a loose connector, the ECU ground wire not hooked up properly, or a broken/bad wire in the harness.
Dale
Old Dec 4, 2006 | 10:57 AM
cewrx7r1's Avatar
Eye In The Sky
Some people had problems with the connector pins for the ecu.
Some pins were push out of the connector so that they did not make contact with the ecu connector. You might have a pin just barely touching.
Pull all four connectors and check all the pins to insure they are in place and rigid.
If not, fix them.
Kyo
Apr 13, 2019 09:24 AM
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
gtcd
30
Aug 19, 2015 02:44 AM
sYnth.
Aug 17, 2015 07:28 PM
