Microtech Question about 2 trailing coil packs
Old Nov 29, 2006 | 04:24 PM
lowkee33's Avatar
Slo Low
Could I use to trailing coil packs with the ltx8 and take out the ignitors or will I have to replace my leading coil pack with an aftermarket.
Old Nov 30, 2006 | 06:27 PM
rx72c's Avatar
Top Answer: 1
You can use s4/5 trailing coil packs for leading and trailing minus the ignitors.
Old Nov 30, 2006 | 08:44 PM
lowkee33's Avatar
Slo Low
Thank you much for the answer that helps me a great deal. I will try it with the ltx8 and I will get back and let everyone know how it goes.
Old Dec 1, 2006 | 08:47 PM
RotaryBuddha's Avatar
CURVE OF CONSTANT WIDTH
espically with the lt8x. you cant use the stock leading coil. you need either two trailing packs or some aftermarket ones. check out my pics. i have done this and it works great.
i know its a mess. but you can see i used two trailing coils. i also switched to all bur9eq for spark plugs.
http://i21.photobucket.com/albums/b2...2/000_1244.jpg
Old Dec 2, 2006 | 05:06 PM
lowkee33's Avatar
Slo Low
I used the 2 trailing packs and I know have hella spark. The bad is know I have no fuel. I can hear the fuel pump running but there is no fuel what so ever.
Old Dec 3, 2006 | 10:22 AM
Aaron Cake's Avatar
Engine, Not Motor
Fuel lines backwards? Common mistake.
Old Dec 3, 2006 | 12:16 PM
lowkee33's Avatar
Slo Low
I will check today but I think they are right. I have actually hooked them up backwards before so it is possible.
Old Dec 18, 2006 | 04:29 PM
rx72c's Avatar
Top Answer: 1
Tell me abou it.
The factory coil packs are much stronger then the bosch coil packs.
They are a real good coil pack.
