v8 mazda guys what hood scoops are you using
Old Nov 19, 2006 | 07:05 PM
5.0 mazda's Avatar
i have no hood clearence the carb is sticking out of the hood by 3/4 of a nich . what out any spacers all motor and intake .thanks 5.0 mazda
Old Nov 19, 2006 | 07:11 PM
Dan_s_young's Avatar
Turbo widebody FB
Out of the 1st gen tech section and to Torquecentral.com...
Old Nov 20, 2006 | 02:16 PM
stilettoman's Avatar
No, it is not stock!
Steel is good!
I needed about 1.5 inches, used a piece from a damaged 280Z hood. The bulge from an Eclipse hood would also work. The hood bulge was the easiest part of my project. Photos shown here:
www.cardomain.com/ride/646433
Old Nov 20, 2006 | 04:33 PM
old sparks's Avatar
stilettoman;
I was hoping not to modify the hood on mine by using the shortest intake I could find, the 7515 X-celerator - it's a little more than 1/2" shorter than your RPM. I guess now I'll have to cut the hood to get the 13" Ford drop-base aircleaner to fit...
Is your crossmember reversed so the doublehump oilpan straddles it? If yes, how far above the crossmember is your oilpan?
thanks
Russ
Old Nov 20, 2006 | 06:08 PM
5.0 mazda's Avatar
Originally Posted by old sparks
stilettoman;
thanks
Russ
yes crossmember reversed i am using a canton 7gt oil pan . pan is 1/4 nich from crossmember my intake is from paker it called webfunnel it is 2nichs taller then vic jr intake. the x-celerator shod fit.
Old Nov 20, 2006 | 10:30 PM
skyburner's Avatar
ok, totally dumb question that is totally off subject. what do you guys mean by "crossmember reversed"? I can't visualize how this would work and maintain rack mounting geometry. Help me to understand this with some pics. Thanks. Also I should say I have an FC.
Old Nov 21, 2006 | 04:22 AM
When I researched my project, I found a Wieand manifold that was lower than anything else I saw.
On my car, I cut the center section out of the crossmember, reversed it and welded it back in, with the welds just inboard of the frame rails. This moves the crossmember a little more aft than reversing the crossmember, because the mount bolts are not symmetrical. I used a front sump oil pan, and had to trim it a bit to clear the crossmember.
You can see the welds in the attached photo, and also the joggle in my sway bar to clear the pulleys. If you need this done, any muffler shop can recontour it in their tube bender.
Attached Thumbnails v8 mazda guys what hood scoops are you using-lowfront-medium-.jpg
Old Nov 21, 2006 | 12:12 PM
old sparks's Avatar
Thanks. I thought your engine had some decent clearance from the firewall. I guess I'll find out soon enough.
Skyburner - using a 302 with a Mustang double-hump pan in a 1st Gen/FB and Granny's mounts, you have to reverse the crossmember so it fits between the two humps.
http://www.torquecentral.com/showthread.php?t=14503
Old Nov 21, 2006 | 03:23 PM
skyburner's Avatar
But not in an FC? I have searched both forums on this and found nothing to say yes or no on it. Thanks.
Old Nov 21, 2006 | 04:32 PM
old sparks's Avatar
Doesn't the Granny's FC/SBF kit come with a complete engine cradle?
http://www.8ntrite.com/images/Constr...0place_jpg.htm
Old Nov 28, 2006 | 03:25 AM
Schmuck's Avatar
Newbie
I have the same issue. I just got my hands on an '86 with a 351W installed, but the guy who did it had to put a hole in the hood and the air cleaner is sticking pretty much all the way out of the hood. If I want to drive it on a less than sunny day, I'm going to have to get an induction scoop on it or something.
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
