Haltech spark question on e6k
Old Nov 11, 2006 | 03:32 PM
Houstonderk's Avatar
My girl
My 86 has an e6k and for some reason there is no spark only when cranking. When the key is turned on it sparks and when stopping from cranking you can see the plugs fire, but not during cranking. The CAS lookes wired right along with the coils. Has anyone ran into this before?
Old Nov 11, 2006 | 07:58 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
What is your setup? Are you getting RPMs when you crank? did you wire up the ignition properly? What engine are you running?
Need more details to find out what is wrong.
Old Nov 11, 2006 | 08:07 PM
My girl
its still the stock ignition setup. It shows rpms on the haltech data log when cranking and the inj pulse is also shown. I think i may have seen direct fire on the menu which would probably cause that, but it started to rain but it was on dist. and still the same thing. Its an 87 Tii block half bridged with a t04 turbo, just want to see the spark all the time.
Old Nov 11, 2006 | 08:52 PM
RETed's Avatar
How is the power side of the wiring to the coils?
Is it still stock?
Or did you custom install it?
If you did redo the wiring, did you make sure it has +12VDC when the ignition switch is in the cranking position?
-Ted
Old Nov 11, 2006 | 09:12 PM
My girl
ah that probably would help. I think the last guy wired it to a 12 volt on in the ignition switch.
Old Nov 12, 2006 | 12:02 AM
RETed's Avatar
Oh snap!
Shoot the bitch!
Good luck!
-Ted
Old Nov 12, 2006 | 01:49 PM
My girl
Well now it has power on both on and cranking but still no spark during cranking. on the data page it goes to reconnect haltech during crank so that would probably cause something, but i can make it spark if i took out the cas and turned it manually. Time for more diag i guess.
Old Nov 12, 2006 | 03:22 PM
My girl
got it working right. Just almost starting but not enough, and give it alittle gas and pops and nothin. guessing to much gas probably.
Old Nov 13, 2006 | 03:44 PM
EFI Tech Wannabe
What size injectors do you have? you got a wideband? are you plugs wet? or not?
Old Nov 14, 2006 | 06:27 AM
My girl
I don't have a wideband yet. Their stock Tii injectors for now but just to get it to idle. I was using the street port map first since mines a half bridge but probably going to try the stock one this week. During cranking it makes like a backfiring sound but not too loud.
Old Nov 14, 2006 | 10:22 AM
EFI Tech Wannabe
You have a halfbridge with stock 550cc injectors?? my guess is that you're super lean, and prolly the map you have is for bigger ones.
Old Nov 14, 2006 | 12:33 PM
My girl
Actually yea that probably could be it. I was wanting to get some 850cc for primary and 1000cc for secondary later on. When i get a wideband I'll check it out. Thanks
Old Nov 18, 2006 | 06:59 PM
My girl
Also I just found out that it needs to be cranking faster than 180 rpms and found the starter bad so maybe it will start at higher rpms?
Old Nov 18, 2006 | 08:49 PM
RETed's Avatar
Yeah, getting the Haltech to first crank and start is a bitch.
You need a fully charged battery, and having a big battery charger nearby is always a good idea.
-Ted
Old Nov 19, 2006 | 11:55 AM
My girl
After messing with the timing, i've found that putting it on time it sounds like it backfires itself and slows down, so i turned the cas one tooth clockwise and it sounds so close to firing that its getting aggrevating. Guess i'll just have to wait till i get a wideband to figure anything out which is gay.
Old Nov 19, 2006 | 06:17 PM
My girl
Just finding out that RA seals and used housings don't go well together at the beginning and hearing alot of people pull starting the car and taking roadtrips to get them to seal. Anyone else heard about that? Knew i should have went OEM.
Old Nov 20, 2006 | 04:09 AM
walken's Avatar
Registered Loser
i've had the same problem and it was the timing. the stock way would't work at all, but the hitman method fired up first try.
Old Nov 21, 2006 | 01:37 PM
EFI Tech Wannabe
Hey, i just noticed you're in Panama City, FL, want me to work on it and see if i can get it to run? email, PM or Call me.... 678-437-0589... Im in Georgia now.
Old Nov 22, 2006 | 06:18 PM
My girl
I just got back from austell for hyundai school and got back today, but yea I've just been messing with it every now and then because of it being cold for me. lol
Old Nov 26, 2006 | 02:12 PM
My girl
Holy hell a crap! My heart is still beating like crazy because I got it to start up and ooohhhhhwee. I just went to the parts store and figured I'd buy some starting fluid and use it and brap brap brap until i stopped spraying because of the white mile wide cloud of sweet MMO smell. lol So either the injectors aren't firing or it is running lean like you said but it started so mission 1 accomplished.
Old Dec 3, 2006 | 05:43 PM
My girl
Jess I bumped the hell out of the fuel map, primer map, cooant map, and air temp map, and it still only starts on starter fluid. How much of a difference should the fuel maps be between a street and half-bridge?
Old Dec 11, 2006 | 06:35 PM
My girl
Ahhh. Stupid me. I was so confident in all the wiring and stuff, but finally found a way to keep the injectors from flying out the rail, and found during cranking the front prim was only working so, get to find out whats up with that and maybe get to see how good that base map will work.
rgordon1979
40
Mar 15, 2022 12:04 PM
_Tones_
May 25, 2021 05:37 AM
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
Nosferatu
Sep 5, 2015 02:13 PM
