Progress on the 7
Old Oct 19, 2006 | 01:11 PM
stylEmon's Avatar
FC since 99
Progress on the 7
Made a blog to document my engine build. I am little bit further than the blog states, but waiting for pics. What do you think?
http://87rx7.blogspot.com/
(Moderators Note: The thread owner has requested this thread stay in the technical forum and not be moved to Non-Technical/Pictures).
Old Dec 13, 2006 | 11:00 PM
stylEmon's Avatar
FC since 99
Giving props where props are due... Elliot White and Nick H. Nug of Turblown Engineering are doing and amazing job on this engine build.
Thanks fellas.
Dang, that's HOT.
After a nice wax, the Wife and I took her for a ride to South Mountain and snapped some shots.
Hot Start Issue..?
Everytime I take short trips in my car, it has problems starting back up. I had this problem with my last RX7, but it wasn't this bad. This car has a fuel cut switch, I am always able to get the car running reletively fast, but this shouldn't be happening on an engine with 5k!
So I took the injectors out. I had them flow tested at AZTPI.com . They were VERY knowledgeble and helpful when it came to injection systems (though the same wasn't true about rotary engines). Turns out, the injectors are fine. So it must be something with the workmanship of the engine...
DUN DUN DUUUUUNNN!!
Blew the engine after doing ONLY 110mph, and then a couple donuts with my bud McNerney. Man, is that thing dirty.
Some Junk We Found
Cracked and VERY worn rotor housing.
Busted coolant seal. This explains the coolant I had in my oil, but how did the gas get there...?
Port job done with a chisel!
Trashed Rotor. (Makes a nice paper weight at work though)
The sad thing is, this motor supposedly had 5K on a rebuild. The engine had oil and grease caked on it. There were multiple stripped bolts, electrical tape on the Turbo inlet duct, and JB Weld EVERYWHERE! Before it blew, the engine was compression tested at about 65-70 psi.
The Old Turbo
The old Series 4 turbo was pretty cracked up. I decided to ditch it and go for the Series 5. More on that later.
Pretty Clean for a Rebuild... HA HA
Just a quick glance at the nasty-ness we found in this 5k old engine.
Put Your Shades on for THIS One
This is what building a Rotary Engine is all about. BRAND NEW ROTOR HOUSINGS. Aren't they pretty.
Finally, A Real Port Job.
Now this port has a purpose and will actually help my engine breath., and it won't create over-lap or blow-by.
Old Dec 13, 2006 | 11:02 PM
stylEmon's Avatar
FC since 99
Group Shot
Enter the Series 5 Turbo
I bought this from 87 t-66 along with the Series 5 Manifold. Thanks for a well-kept turbo and a helluva deal. This is what it looked like when I got it. Not bad, but we've added some surprises to this seemingly stock turbo. All I can say at this point is, the waste gate has been ported, and the serial numbers above the waste gate door have been shaved off. The other surprise on this baby is coming soon.
A Well Balanced Engine
Elliot and Turblown sent the engine internals out to another shop for the balancing and it almost killed me. I waited 8 weeks for the balancing to get done. The shop had balanced MANY engines, but never done a rotary before. They were suprised to learn that the rotary engine can be upto 50 GRAMS off balance and still be considered 'with-in spec.' After much anticipation, I FINALLY got the internals back, and they are now with in 10 grams. This will make a supurb difference in reaching my Torque goals and even a bigger difference in the reliability of this motor.
I'd also like to point out my new ACT clutch (pressure plate shown here). Thanks Elliot. My old one was toasted, and Elliot sold me this one for a bargin. The fly wheel was balanced with the plate on it.
Speaking Of Suprises...
Recoated turbo
The Real suprise is this PolyDyn coating that most of my engine is getting. This stuff really helps with heat reduction. If you know anythign about the 13b, it's one hot engine. It can be a real pain to find an EGT gauge that will give you a good reading.
Heres how it all hooks up. Looks pretty blingin! I got this PanSpeed Down Pipe from Japan2LA. It still has quite a few miles left on it too. Along with the coating, the DP got a new bung for the EGT probe, and everything fits nicely.
Picked Up A Few Goodies
Things are starting to come together now. The Engine is nearing completion so I made a big push to get my fuel system together. I ordered this Walbro 225lph HP and the AEM Wideband from NoLimitMotorsport.com. After a night of heavy debate, I decided to go with the Lambda reading over AFR, though I am still not exactly sure what Lambda is... The 720s are from Fatty_FC3S. Haven't flow tested them yet but the wire clips look good.
Problems, Always Problems
Things were going a little too well, so my wire harness decided to crap out. This is what's left of my wire harness. I was planning on using an Rtek but now that my harness is shot, I am forced to re-evaluate. I am thinking Haltech at this point, so once the engine is built I may have to put the project on hold until I find the system I want
Old Dec 13, 2006 | 11:45 PM
dwb87's Avatar
This is my social media.
Looks good... and fun
Old Dec 13, 2006 | 11:48 PM
Mushy B's Avatar
red x's on the first rebuild that he bought or the second one in the blog he's done?
Old Dec 13, 2006 | 11:54 PM
Sideways7's Avatar
Excellent looking engine. I enjoyed the shiny goodness that is new rotor housings.
Old Dec 14, 2006 | 12:20 AM
darktritium's Avatar
spazz!
Wow. Your journal (blog) is looking good. Keep us up to date with this stuff.
Old Dec 14, 2006 | 08:42 AM
RE-Amemiya's Avatar
Not the company
+1!
EDIT: (Pics worked for me after i refreshed the page)
Old Dec 14, 2006 | 11:25 AM
stylEmon's Avatar
FC since 99
crap! it looked fine last night...
well thanks for all your comments. Its been a test in patients
You can see the actual blog here...
ps. i didnt pay for the first motor. when i bought the car it suposedly had a 5k old engine in it...
Old Dec 15, 2006 | 11:58 AM
stylEmon's Avatar
FC since 99
maybe I've posted toom any pics?..
Old Dec 15, 2006 | 12:02 PM
cmanns's Avatar
Smoke moar
No, red x means not a valid link. btw
Otherwise looks nice
Old Dec 15, 2006 | 12:07 PM
87 t-66's Avatar
not a drifter
lookin great, nice turbo
Old Dec 15, 2006 | 12:35 PM
stylEmon's Avatar
FC since 99
LOL...
ya, bought it from some shmo...
Old Dec 15, 2006 | 01:08 PM
stylEmon's Avatar
FC since 99
thats wierd cause the links are all valid. I copied the location of each image from the blog site, and they are all still there...
Old Dec 19, 2006 | 02:11 PM
stylEmon's Avatar
FC since 99
hey guys, feedback on the new rotors...
Old Dec 19, 2006 | 10:41 PM
spazz!
Lookin' good!
Old Dec 20, 2006 | 11:47 PM
apexFD's Avatar
Wow that is a thing of beauty! I would buy a new rotor as an art peice. BTW is that turbo a stock S5 turbo?? I am assuming it is, i am going to be porting a an s5 wastegate soon, just wondering if that what it looks like. Thanks
Old Dec 21, 2006 | 01:09 PM
stylEmon's Avatar
FC since 99
thanks man, I cant wait to get this assebled! These rotors are actually balanced and coated, not brand new, but prob better than new. That is an S5 turbo, also coated. the porting on the wategate should allow for 15+ lbs of boost. thats why I am going methanol so I can keep the stock intercooler for now. good luck with the porting.
Old Jan 10, 2007 | 08:48 PM
stylEmon's Avatar
FC since 99
coming together now. putting FD stationary gears in, ordered the bearings today! Bearings went in the rotors. Wont be long now.
Old Jan 16, 2007 | 10:03 PM
stylEmon's Avatar
FC since 99
Got the housings back in today. Lovin it! Now for the question of the century, haltech or motec?!!?
Old Jan 17, 2007 | 12:12 AM
MaczPayne's Avatar
Mac Attack
Haltech. E6K. Do it.
Buuuuttttt....... I got a MicroTech, only because it was such a steal.
Yeah, I'm a bastard.
Old Jan 17, 2007 | 12:08 PM
stylEmon's Avatar
FC since 99
All Hail COATED Rotor Housings
It didn't take very long for these to get coated. The exhaust port was ported before the housings were shipped out. Now that I have these back, the motor will be assembled. I don't have any pictures yet, but I also picked up FD stationary gears. They allow more oil to get to the bearings (which are also coated). Should have picks of the gears soon.
Old Jan 17, 2007 | 12:15 PM
stylEmon's Avatar
FC since 99
http://www.motec.com/products/ecu/control.htm
supposedly, they have supurb software and have more inputs than haltech
Old Jan 17, 2007 | 02:45 PM
reboot's Avatar
i spent more on tires...
is that your garage? clean
Old Jan 17, 2007 | 03:38 PM
Syncro's Avatar
Buildup Thread Encourager
I *love* to see well done projects!
Ghetto 7's make me sad
