has anyone ever had the winking headlight sindrom
Old Mar 2, 2002 | 11:02 PM
amemiya's Avatar
every once an a while my right headlight goes insane and goes up and down up and down, for like 3 min than stops. has anyone else seen this???
Old Mar 3, 2002 | 12:13 AM
RETed's Avatar
You've got a short in the headlight motor circuit...
-Ted
Old Mar 3, 2002 | 12:33 AM
amemiya's Avatar
it only does it when it is cold I thought it was a bab conection or relay.
Old Mar 3, 2002 | 12:53 PM
RETed's Avatar
No, it can't be an open circuit.&nbsp If it was an open circuit, it wouldn't do anything at all.&nbsp The headlight retractor motor works by +12VDC to go up and -ground to go down.&nbsp If you've ever tried to raise the headlights manually (**** underneath) without killing the headlight motor power (via fuse), the bitch slams shut on you; the system is still seeing -ground.&nbsp So to trigger the headlights to close, you need a -ground signal somewhere, which implies it's a short to -ground.
-Ted
Old Mar 3, 2002 | 06:03 PM
amemiya's Avatar
man guess it'stime for the RE amemiya kit
Old Mar 3, 2002 | 06:36 PM
Juan's Avatar
Im a tall midget.
or duct tape a flashlight to your hood
Old Mar 4, 2002 | 04:43 AM
amemiya's Avatar
I need to get some cool xenon bulbs, I feel like I have been driving with candles in the front.
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
