What would cause No Boost?
Old Mar 2, 2002 | 09:52 AM
rsa's Avatar
rsa
After breaking in a replacement motor that was limited by 6lbs boost for 1000mi, by using an enlarged pill, I am unable to get boost over 6lbs. I replaced the enlarged pill with a Holley .064 jet but it has no affect. What else should I look at? Thanks.
Old Mar 2, 2002 | 10:26 AM
Bucrx7's Avatar
Does the first turbo go over 6 psi? In order for the second turbo to come online the first turbo needs to reach at least 8psi. Drive around and see if you hear a hissing sound, if so then it's a leak somewhere.
Old Mar 2, 2002 | 10:38 AM
rsa's Avatar
rsa
It goes to about 6 or 7. There is a good punch at 4800rpm so I assume the 2nd turbo is coming online. There are no hissing noises at all.
Old Mar 2, 2002 | 10:57 AM
Bucrx7's Avatar
What's the max boost after 4500 rpm? Does it stay at that number or does it drop? Or does it climp up SLOWLY as it revs?
Old Mar 2, 2002 | 05:04 PM
rsa's Avatar
rsa
It stays right at 6psi all the way. No variation.
Old Mar 2, 2002 | 05:40 PM
funnyguy_11's Avatar
Could it be the vacuum line for the boost sensor?
Old Mar 2, 2002 | 06:51 PM
Bucrx7's Avatar
Sounds like a clogged cat. Is is the original cat? How much mileage?
Old Mar 3, 2002 | 09:47 AM
rsa's Avatar
rsa
Only 30,000 mi. Car has Pettit exhaust, DP, PF IC, & Pettit ECU.
When I first wanted to bring the boost back up to snuff, I installed a Profec B, but it refused to have any affect on the boost. I thought it was defective so I removed it and went back to the pills. Now I realize there probably isn't anything wrong with the Profec. The vac line seems fine. The Profec was seeing low boost and no matter how high I turned up the adjustment it had no affect.
Old Mar 3, 2002 | 11:48 AM
Flybye's Avatar
It's never fast enough...
Have you checked your wastegate and precontrol actuators? They may be sticking causing them to stay open
Old Mar 3, 2002 | 04:52 PM
saiyan's Avatar
Awhile back i replace my vacuum hose and replace the hose that connect to the actuator(wastegate control, or turbo precontrol) forgot which one, but I replace with a regular silicone hose without the pill. Could this cause boost problem, cause I only get about 7-8lbs of boost after 3500rpm to redline. Sounds like my second turbo doesn't kickin.... help?
Old Mar 4, 2002 | 05:44 PM
rsa's Avatar
rsa
Flybye, how do you determine if they are sticking?
saiyan, you need the pills installed.
Old Mar 4, 2002 | 06:28 PM
saiyan's Avatar
I know, I threw away my old hose... Does dealer sell these hose with the pills in it? or where can i get these pills?
Old Mar 4, 2002 | 07:02 PM
rsa's Avatar
rsa
You can use Holley carburetor jets.
Check out http://www.scuderiaciriani.com/rx7/turbos.html#PIL
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
