Haltech last problem with haltech
Old Oct 6, 2006 | 05:34 PM
parm.singh's Avatar
Everytime i try to connet to my haltech it says "unable to open com port, please ensure...." Something along those lines. I tried it with 2 laptops,windows xp and 98. I tried it with f10x and a f9. I downloaded the software from HALTECH.COM and i have no idea what to do.
Old Oct 6, 2006 | 06:47 PM
funklove's Avatar
In rotor we trust!
Do U use USB-com adapter?
Old Oct 6, 2006 | 08:12 PM
parm.singh's Avatar
Yes i do. I installed the driver and everything. I DON'T KNOW WHAT TO DO!!!
Old Oct 6, 2006 | 08:24 PM
AnthonyNYC's Avatar
Stay tuned...
Switch the comm ports on the USB software. Try each com port. Did you buy the radio shack serial to usb converter?
Anthony
Old Oct 6, 2006 | 09:50 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
What USB to Serial addapter are you using, there are units that DONT work. I always recommend the Keyspan USB to Serial addapter, works everytime, no hickups.
Old Oct 7, 2006 | 12:03 AM
parm.singh's Avatar
I have the radio shack one. I just can't stop trying to think what to do. I did almost everything.
Thanks
Old Oct 7, 2006 | 02:01 AM
funklove's Avatar
In rotor we trust!
I bought chinese adapter for 20 bucks and it works great. Install USB-COM software and try to choose a proper com port.
Old Oct 7, 2006 | 12:18 PM
Sesshoumaru's Avatar
Tenseiga
make sure your key is on the On position when you try
Old Oct 7, 2006 | 12:47 PM
EFI Tech Wannabe
These days communication problems are more often than not brought on by the use of an incompatible USB to Serial adapter, this is why i always recommend the Keyspan, and never get either really really cheap ones or from ebay, unless you're getting what i recommend. If you dont, its a 50-50 shot of it working, either it does or doesnt.
Old Oct 8, 2006 | 05:54 PM
tims's Avatar
$50 cheap *** DOS laptop is best solution. these older ECU's were designed to use DOS. I bought my cheap Compaq for $100 a few years ago and it works perfectly. I have not had any luck with the USB adapters or XP. good luck
Old Oct 8, 2006 | 06:45 PM
YayeR's Avatar
+1 for Keyspan USB-Serial Adapter.
I had tried another one with no luck, when I switched to the Keyspan it worked no problem and works every time.
Old Oct 8, 2006 | 09:25 PM
EFI Tech Wannabe
Dang man, you're in tallahassee, i was there a few weeks ago, working on some cars, strange that you didnt see my post on going there.
Did that comment of yours say that you got it to work with the keyspan? I actually use it with my P3 laptop with WinXP, and i also use Virtual PC for the DOS stuff, but my lappy has a serial port, and i dont have any issues .
Old Oct 9, 2006 | 09:27 AM
Aaron Cake's Avatar
Engine, Not Motor
I have all kinds of problems with USB to serial adapters with standalones. Most of the software isn't written very well so it is easily confused. To solve this annoyance, I purchased a PCMCIA to serial adapter and have not had a problem since...
Old Oct 9, 2006 | 03:17 PM
EFI Tech Wannabe
Yes, PCMIC serial adapters are known to be reliable also. But like i say, and will keep on saying it. the KEYSPAN one WORKS everytime. I think i should hit them up for some corporate sponsorship, since i push their product so much!
Old Oct 9, 2006 | 04:31 PM
parm.singh's Avatar
I'd like to thank everyone for the help and advice!
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
