Loosing power after 4000 rpm, HELP!!!
Old Mar 2, 2002 | 12:11 AM
vadym's Avatar
losing power after 4000 rpm. I got my 89 NA 2 month ago and noticed that my air pump is missing, so probably my 5th and 6th ports arent working so may be thats why im loosing power. If so do i wire the 5 th and 6th, or do i have to take port slaves out. If so can anyone tell me how to do it?
Old Mar 2, 2002 | 03:19 PM
Even assuming the 5 and 6 ports are not opening you should not have a big drop in power above 4K. My engine does not begin to hit the big power band until 5K.
Check your secondary injectors. It sounds like they are not working.
As far as keeping your 5 and 6 ports open, just open them by hand (if they are not stuck shut) and wire them in that position. Expect a power loss at low engine speeds if you do this.
Old Mar 2, 2002 | 03:38 PM
presetlimits's Avatar
do you still have your cats on the car? if so, with the air pump removed the cats are clogged and the reason for the power loss.
Old Mar 2, 2002 | 04:12 PM
vadym's Avatar
how do i open them by hand and how do i wire them???? No, i dont have a cat.
Old Mar 2, 2002 | 04:57 PM
ajsuper7's Avatar
Nothin But a G Thang
sounds like stuck 5th and 6th ports, im sure there is a writeup on how to wire them open . do a search on the forum
Old Mar 3, 2002 | 12:17 PM
HAILERS's Avatar
HAILERS
Get a airpump so your aux actuators open and your VDI works.
Queppa
Nov 18, 2024 03:47 AM
C. Ludwig
Jan 30, 2019 06:31 AM
The Shaolin
Sep 14, 2015 07:50 PM
Microtech
Aug 23, 2015 11:04 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
