stock fuel pressure regulator ??
Old Mar 1, 2002 | 08:46 PM
rx7passion's Avatar
ok this is for people with a turbo 2, do you hear hissing coming from your regulator of any kind?. my car doesnt start under its own power and my regulator makes a hissing sound i am wondering if it is defective or if this is normal?? thanks in advance
Old Mar 1, 2002 | 08:49 PM
RETed's Avatar
Normal..sounds like water running through it?&nbsp That's the sound of gas going through it - it's doing it's job!
-Ted
Old Mar 2, 2002 | 02:49 AM
tweaked's Avatar
might be a vacume leak somewhere close like that vac line going to your regulator. be sure to check it out that would keep it from starting easy but able to run once you got it. look close those bastards are hard to find. really hard if it is a cracked line.
Rotospectre
Mar 28, 2018 03:33 PM
