Wish List, what do you think?
Old Mar 1, 2002 | 07:33 PM
Sloraxe's Avatar
Ok, let me know if i'm missing anything, this is my personal preference in how I would like it, Planning on doing this later this year or next year, so all you guys that have been down this road let me know if somthing in this set up is bad, or wrong, or missing somthing ciritcal.
All of this is I plan to do on a 94 touring.
Steering wheel $160
Pedals $60
Mazdaspeed Leather Shift **** $55.00
GT-C Rear Wing $850.00
GT-C Front Bumper $940.00
Vacuume Hoses $200
Pettit's AST - Cant Find price est: #120
HKS 60mm Electrical Temprature Gauge with Peak Hold/Warning $279.00
Racingbeat Dual Tip Exhaust System: $475.00
HKS Downpipe $199.00
Koyo Aluminum Radiator $375.00
Apexi Power Intake System $399.00
HKS 60mm Mechanical Boost Gauge (Black Face) $114.00
Apexi Power FC $850.00
Greddy Turbo Timer $125.00
Pettit High Flow Cat. $495.00
Nippondenso Competition Fuel Pump $250.00
Bosch 1600cc Injectors $125.00 Per $500 total
SX Adjustable Fuel Pressure Regulator 35-90 PSI $163.50
ACT Street/Strip Clutch + 10lb Aluminum Flywheel (Includes counterweight) $885.00
Mazdaspeed Short Shift Kit $289.00
M2 Strut Tower Brace $189
M2 Ball Bearing Twin Turbo Upgrade Set $2995
And to top it off: 13B STREET PORT W/ SPECIAL HD 3MM APEX SEALS $3599.95 (From Pettit)
Old Mar 1, 2002 | 07:40 PM
black99's Avatar
Lurking..................
1. You are going to want/need something to tune the PFC... Either the datalogit software or the handheld controller
2. You don't want/need 4 1600cc injectors, I think just 2 1300's in the secondary's place would be enough
3. The power intake system you can get from Jason at rx7store for $212.00 I believe.
The brands of products you picked seem ok to me..
Old Mar 1, 2002 | 07:43 PM
black99's Avatar
Oh and if you are doing the hose job yourself you should be able to get the hoses or even a hose kit from hosetechniques.com for less than $200.00..
Old Mar 1, 2002 | 07:45 PM
94touring's Avatar
I'd skip all the body kit stuff and put it toward performance parts. Instead of upgrading twin turbos for 3k, I would spend 3k on a single turbo. Heres my list of what I would do.
Old Mar 1, 2002 | 07:46 PM
Sloraxe's Avatar
Cool man, 2 1300cc injectors, was a stab in the dark on that.
And I will include a commander then with my ECU, so add another 250.
Hoses and plugs and plug wires I guess would be around 200.
Add another 5k for labor, think thats enough? Trying to keep it all under 20k.
Old Mar 1, 2002 | 07:52 PM
94touring's Avatar
Hey, what about an intercooler? Oh, and you don't really need a fuel pressure regulator untill you get into some massive hp and high boost.
Old Mar 1, 2002 | 07:58 PM
Sloraxe's Avatar
I hear ya, but I like that look, Plus, I dont really like the single turbo set up, from what I have READ, correct me if I'm wrong, I have yet to drive a single turbo 7, but I hear bad things about the low end. I like twisty roads and still think that the twins is plenty, this setup is going to take me to 400HP and I'll still have power under 4k...
Old Mar 1, 2002 | 08:00 PM
Sloraxe's Avatar
So Intercooler would be better then fule reg, true I im thinking about keeping it under 14psi boost, I think that would be plenty for my blood.
Thanks for the feed back, First time doing this and I want it done right
Old Mar 1, 2002 | 08:10 PM
94touring's Avatar
Yeah, skip the fpr. I would go with the apexi fmic and intake system....somewhere around $1200. I am using the apexi single turbo, which has hardly any noticable lag and is ball bearing also. The m2 twin system will lag just as much as this turbo, since they have been enlarged. Basically both are capable of the same amount of power, but this will clean up your engine bay and keep things really simple. You can also take off the intake system, downpipe, and any kind of wastegate modifications since the kit comes with these.
Old Mar 1, 2002 | 08:19 PM
94touring's Avatar
Heres a pict of what it would look like, and add a blow off valve to your list.
Old Mar 1, 2002 | 08:21 PM
rx7speed811's Avatar
Accepting Donations.
youre getting the kit and spoiler without sideskirts, rims, or suspension? it might look kinda funny, but i guess thats the look youre going for...
you might probably consider getting a bigger intercooler if youre going to get that deep into the game.
besides that, it sounds like a plan to me
Old Mar 1, 2002 | 08:25 PM
Crazy_Jake's Avatar
If your running an open exhaust (downpipe, midpipe, cat-back) you will probably not notice the turbo lag unless you're running a huge turbo. And the available power will be much bigger. More potential, and more reliable.
Old Mar 1, 2002 | 09:03 PM
Johnny's Avatar
OG
Re: Wish List, what do you think?
Steering wheel $160...are they that cheap...$230 for my mazdaspeed and that didn't include the hub
Pedals $60 just get s cwr widefoot pedal
Mazdaspeed Leather Shift **** $55.00 sounds about right
GT-C Rear Wing $850.00 I love that wing too
GT-C Front Bumper $940.00 good choice..side skirts maybe
Vacuume Hoses $200 more like 400 if you want somebody to do it for you
Pettit's AST - Cant Find price est: #120 personally I'd eliminate it..~60 bucks
HKS 60mm Electrical Temprature Gauge with Peak Hold/Warning $279.00 water temp???why the PFC will do that
Racingbeat Dual Tip Exhaust System: $475.00 [COLOR=red]good choice /COLOR]
HKS Downpipe $199.00 with the money I just saved you on the above temp gauge..buy a better dp..something SS..m2,sr,pettit,rx7fashion
Koyo Aluminum Radiator $375.00 sounds about right
Apexi Power Intake System $399.00 my personal fav intake box = rx7fashion
HKS 60mm Mechanical Boost Gauge (Black Face) $114.00 sounds about right
Apexi Power FC $850.00 try around 1100 if you want a commander which I highly suggest
Greddy Turbo Timer $125.00 sounds about right
Pettit High Flow Cat. $495.00 sounds about right
Nippondenso Competition Fuel Pump $250.00sounds about right
Bosch 1600cc Injectors $125.00 Per $500 totalw/1600 you are no longer side feed meaning you need a fuel rail also..highly recomment getting the 850 magically turned into 1300 like other have suggested
SX Adjustable Fuel Pressure Regulator 35-90 PSI $163.50personally I dont think you need it at this mod level
ACT Street/Strip Clutch + 10lb Aluminum Flywheel (Includes counterweight) $885.00 sounds about right
Mazdaspeed Short Shift Kit $289.00 sounds about right
M2 Strut Tower Brace $189sounds about right
M2 Ball Bearing Twin Turbo Upgrade Set $2995sounds about right
sounds about right
Johnny
Old Mar 2, 2002 | 01:29 AM
mightyslash's Avatar
Will Work for Ferrari
I think the total cost is gonna be a little bit higher than what you expected.
Old Mar 2, 2002 | 10:16 PM
Sloraxe's Avatar
Thanks for the large response, I will most likely redo my list in favor of keeping it all under 20k including the labor that I will need, some things I can do myself, but not all.
Man getting very difficult to get everything I want for what my current budget is . I'm looking hard into a single turbo system now, and will prob end up forgoing the new motor and just run my current one until it goes south. Suspension and breaks will also need to be added, thanks.
Old Mar 2, 2002 | 11:08 PM
94touring's Avatar
Just to give you an idea of price. I added up everything on my list and it roughly comes out to about 12k. That doesn't include the new street ported motor, or labor.
Old Mar 3, 2002 | 04:16 AM
Nathan Kwok's Avatar
Since you're already spending big bucks, I'd add a J&S and CWR Dual Oil Coolers (or the rotaryextreme gigantic oil cooler) to that list... can never be too safe.
NickNac113
13
Oct 1, 2015 09:25 PM
