Hi temp paint for DP
Old Mar 1, 2002 | 06:57 PM
Ouijan's Avatar
Is there a high temp paint that will last on a downpipe. I saw some paints claiming 1800 degrees and, from other info on this forum, EGT can run up to 800 Celsius. 800 Celsius should translate into 1472 F (800 x 9 / 5 + 32).
Will this paint last or am I just gonna get a smelly and smokey engine bay?
And yes, I've heard about jet-coating - but I like to DIY as much as possible.
M
Old Mar 1, 2002 | 07:04 PM
mjw's Avatar
mjw
I would never consider painting a DP, you will just end up with a smoky, smelly mess.. I would almost bet on it. The DP just gets far too hot for paint to withstand for any length of time, Jet Hot Coat is really the only option for a coating that will not only last.. but also reduce the underhood temps.
Matt
93 SSM
Old Mar 1, 2002 | 07:05 PM
GsrSol's Avatar
Z06 powered FD
I really doubt that coating-in-a-can will do anything or last.
Old Mar 2, 2002 | 07:17 AM
Tim McCreary's Avatar
I saw a post where a DP could be coated for $45. This would be much better than trying to paint it. They had several colors.
Tim
Old Mar 2, 2002 | 08:12 AM
Rotary93's Avatar
Retired RX7 mechanic
Send it to Jet hot for their 2000 degree coating.
I think thats what you say for $45
Old Mar 2, 2002 | 09:50 AM
Bucrx7's Avatar
The $45 was from a pro coating company down in Tampa, FL. They use a product from www.techlinecoatings.com and they have many dealers throughout the US.
Old Mar 2, 2002 | 09:58 AM
j9fd3s's Avatar
Community Builder
even on a non turbo rotary the paint comes right off
mike
Old Mar 2, 2002 | 11:46 AM
Silver93T's Avatar
Braap Braap Braap BOOM!
I used some kigh temp ceramic stuff from autozone. I got the highest temp one they had. I also wrapped the dp with some of that heat wrap. It held up pretty well but last time I ahd the dp off I decided to just send it to jethot. Seams cooler under the trans tunnel now.
Mrmatt3465
Interior / Exterior / Audio
Sep 17, 2015 01:28 PM
OCDHerb
Sep 7, 2015 05:41 PM
