Microtech Timing check !!
Old Sep 30, 2006 | 12:11 AM
BeNO's Avatar
Timing check !!
Could some one tell me if this timing is good, bad, allright.. and if anybody know what the timing should be.
What's the most advance and retarted i can reach ??
would retarting too much detonate or effect the engine as much as Advancing ?
thanks guys
Attached Thumbnails Timing check !!-timing-1.jpg   Timing check !!-timing-2.jpg
Old Sep 30, 2006 | 07:42 AM
C. Ludwig's Avatar
www.lms-efi.com
http://forum.teamfc3s.org/showthread.php?t=41915
Here's a good discussion that includes some safe numbers. How did you save the screenshots? That would come in very handy.
Old Sep 30, 2006 | 01:25 PM
BeNO's Avatar
there is a buttom on the keybord usualy on the right is called ( prt Scrn )
and then open (paint) in program menu and past it there. thats it.
Old Oct 1, 2006 | 12:17 AM
black93RX7's Avatar
20BFD
your t_rpm map looks similar to , believe it goes up to 30 degree.
Low rpm it starts off at 5degrees at idle, this was from the base map.
This is giving me 1200-1500 f egt's at cruise and when I stopped my manifole and snail were glowing red. Wasnt boosting or going above 3k, since its a new engine.
Old Oct 2, 2006 | 10:11 PM
BeNO's Avatar
i don't have egt gauge but i recently change my timing (advance it more)
The car feels smother on lower RPM but i think sometimes i hear clicking sound !! i am not sure if it is detonation or not !! I hope not.
Old Oct 4, 2006 | 02:27 PM
myfc3s's Avatar
That's what she said...
That could be a slow transition from primary injection, and than secondary. Let me guess.. do you hear it @ 3-4k? If so you might want to adjust the maps..
Old Nov 2, 2006 | 10:25 AM
lousrx2's Avatar
Unhappy Water Temp
I have a 71 rx2 and I run a microtech lt8s. My water temp wire from the microtech is hook up to the stock water sending unit. I belive its the purple wire from the lt8s. I also have a mechanical water temp gauge that runs to the water pump. My water temp on the computer reads 106C while my mechanical gauge reads 180F does anyone know why. I would love some help and I must say I've been braking apex seals left and right.
signed need some help
Thanxs.
Old Nov 2, 2006 | 01:53 PM
RotaryEvolution's Avatar
Sharp Claws
at 180F you should be able to grab the upper radiator hose with it being fairly warm but not scalding, at 106C you would not be able to hold the hose for long if at all.
Old Nov 7, 2006 | 10:14 AM
lousrx2's Avatar
Thanks for the reply I like to know if 106c is bad or ok for my engine.
Old Nov 14, 2006 | 02:29 AM
myfc3s's Avatar
too high
Thats too high, I wouldnt go any higher than 96c. But i have seen my temps
go as high as 100c, than i turn her off..
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
PhillyFC
Aug 21, 2015 06:36 PM
