Rear Diff Mount Vendors?
Old Mar 1, 2002 | 11:41 AM
TailHappy's Avatar
Addicted to Track
Found out my rear differential mounts are definitely shot. I need to get them replaced before a track day at the end of the month. I don't really want to go back with OEM ones since I'll probably just bust them again, but I don't really want the side effects of the Unobtanium ones either (gear whine, etc). Does anyone sell heavy duty ones? I searched my usual places and wasn't able to come up with any vendors, and I really need to be getting these things ordered.
Thanks in advance.
Old Mar 4, 2002 | 07:46 AM
TailHappy's Avatar
Addicted to Track
Nobody's done this? I had a recommendation to try Mazda Comp's upgraded ones. You guys all using stock ones?
Old Mar 4, 2002 | 08:13 AM
inukai's Avatar
There are several types ofDiff Mount bush in Japan.
Metal is stiffer but noisy.
Polyulethan is moderate.
Which type do you want?
I use this one.
It is US$200.
Old Mar 4, 2002 | 09:53 AM
TailHappy's Avatar
Addicted to Track
Unfortunately I don't know exactly what I want. I definitely don't want metal, or anything else that's too harsh since the car is my daily driver. However, I've heard that if I buy new OEM ones, I'm likely to break them quickly again. The ones pictured look like what I might have imagined I might need. Were there any real downsides to these (excessive noise, etc)? Where did you purchase them?
Thanks
Old Mar 4, 2002 | 01:11 PM
inukai's Avatar
It is sold at only in Japan.
The shipping cost from Japan isn't peanut.
I will visit San Francisco next month.
If you want this products, I will carry them.
Then, the shipping cost can be saved.
PM me.
Old Mar 4, 2002 | 01:36 PM
KZ1's Avatar
KZ1
how much power do you have that you think you will break stock ones. Aren't many of those single guys with 450rwhp using them?
I know Jim's are noisy with gear whine b/c I have them installed. I assume metal would be the same.
Old Mar 4, 2002 | 01:43 PM
TailHappy's Avatar
Addicted to Track
The stockers may be fine. I'm only looknig at 275rwhp, but I autocross monthly and plan on getting track time regularly. I'm purely going on hearsay, but was told that OEMs would just break again under these conditions. I may just have to just use them again while I decide what to get next. I need to have them replaced before the end of the month when I'll be getting my first track day. Thanks for the offer inukai, but unfortunately I don't think I have that much time.
What was Jim's made from? I'd still be interested if anyone can verify that stock is strong enough...
Old Mar 5, 2002 | 08:14 AM
KZ1's Avatar
KZ1
Jim's are made of nylon. hard as hell. I got th em at teh time becasue they were cheap as hell, something like 80$. I came to find out my stock ones weren't even bad. and Jim's didn't add any throttle response or anything.
If I were to do it again, I woudl go mazda comp or some poly ones. Jim's are greta bushings, made well and very inexpensive. Just a little much for what I need. and I am running 14lbs of boost.
Old Mar 5, 2002 | 09:20 AM
TailHappy's Avatar
Addicted to Track
Thanks for the reply. I may just go the Mazda Comp route. I couldn't find anything listed on their webpage, but they must have them. By the way, does Jim have a website? I see lots of references to his stuff but I've never stumbled across an address.
Thanks!
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
