Megasquirt FD trail spark mode
Old Sep 29, 2006 | 04:03 AM
Jobro's Avatar
SAE Junkie
FD trail spark mode
So when you set this
you set the outputs
as
Spark A
Spark B
and Spark C
Which LEDs are which outputs?
I'm not using FD coils I'm using 4 external ignitors and 4 seperate coils
Old Sep 29, 2006 | 04:08 AM
Jobro's Avatar
SAE Junkie
And how do i interpret the LEDs as which modules to send the signals to?
I looked in the schematics
Theyare called accell etc but they don't show you what pins to use
Old Sep 29, 2006 | 09:51 AM
muythaibxr's Avatar
MegaSquirt Mod
The LED closest to the serial port is leading... the middle is rear rotor, the last LED is front rotor.
Old Dec 27, 2006 | 08:07 PM
THE MAINTENANCE SHOPPE's Avatar
MUYTHAIBXR This is what I was talking about doing on the msnse website, except I would like to fire the coils with vb921's for dwell control. I would like to use one wasted spark MSD coil for leading and to single coils for trailing. The most accurate and powerful igntion hardware for the rotary would be these coils at acost of less than $120 total.
I also spent $150 for an Electromotive 60-2 crank wheel and vr sensor. For a price of $370 to eliminate the CAS and huge factory coils . And create a hell of an accurate and powerful igniton system. The only piece I am missing is the software to support spark output inverted. If it was developed for ms1 or ms2 it would be great. I don't have a problem buying the ms2 when your new software is available.
Old Jan 3, 2007 | 12:52 AM
Testing my signature
dona1326cosprings7
Oct 29, 2015 06:47 AM
GKW
Sep 28, 2015 04:34 PM
