Removal of airpump whit cat still in?
Old Mar 1, 2002 | 01:20 AM
Mindphrame's Avatar
Well I’ve done some searches but I really don’t see anything aside from "your cat is already gone so there is no point for the air pump anyway". Can you remove the air pump while I still have my cat? (pre-cat is gone) I don’t have to worry about emissions testing (yet).
Also, I just ordered a block off plate kit, (doing sequential simplification) does this kit have anything to do with the air pump? I read that you need to plug some hoses I think? Also, I read this not too long ago but I can’t find it again...what belt will fit with the air pump gone? I can’t really afford the pulley kit yet. Soon though....soon.
And on a side note, I’m a big fan of my stereo and my A/C (this is Florida damnit) and as I understand that a pulley kit will under drive the alternator and compressor. Will this adversely affect me? I run 2 JL 10”subs.
Sorry I'm kind of bringing up beaten down subjects lately, but other posts that have the info I need are scattered and dealing with other things. It’s so nice to have all the info you need in one nice tight lil package. I just fear me doing something stupid and then…well……[img]//home.earthlink.net/~mindphrame/_images/nuke24.gif[/img]
Old Mar 1, 2002 | 01:21 AM
mightyslash's Avatar
Will Work for Ferrari
I dont think it's a good idea.
Old Mar 1, 2002 | 01:56 AM
JoeD's Avatar
if you remove the air pump while you are still running the stock main cat, you are reducing its life span significantly. the air pump pumps fresh air into the cat at 3K RPMs and below for it to function properly. you also will not pass emmissions without an air pump...but there are always ways around that.
bottom line...dont remove the air pump before you have gotten rid of the main cat.
Old Apr 4, 2002 | 12:47 AM
DRAG0NEER's Avatar
and why would someone remove the airpump???
Old Apr 4, 2002 | 12:52 AM
Lost Time's Avatar
Chimera Driver
Because it's a useless piece of ****.
Old Apr 4, 2002 | 01:28 AM
rynberg's Avatar
Definitely don't remove the airpump while running a cat. I'm also with Dragoneer, I don't understand why so many people go to the trouble of removing it when it only weighs 9 lbs and only operates below 3000 rpm. Oh well, to each his own.
Old Apr 4, 2002 | 09:22 AM
technonovice's Avatar
Jinx
...but it is still not wise to remove the air pump it until the cat is eliminated.
Old Apr 4, 2002 | 09:33 AM
jmseven's Avatar
Asset is Wealth
I had done this in the past with my T2. But, I had the 3" turbo back with a h/f 3" cat. I actually liked it because the "smell" wasn't as bad.
ZacMan
Sep 19, 2015 09:20 PM
risingsunroof82
Sep 7, 2015 01:11 PM
