Brake Booster Install
Old Feb 28, 2002 | 11:35 PM
AKABILLY's Avatar
Question Brake Booster Install
Has anyone replaced their brake booster? Mine is leaking where the master mounts into it and the black paint is coming off of it and it's still leaking and it looks like ****. I also believe it's causing a vacuum leak. At idle when I depress my brake pedal my RPM's drop some.
I'm contemplating getting into it and replacing it. What am I getting into? Any tips?
Thanks
Old Feb 28, 2002 | 11:40 PM
Scott 89t2's Avatar
SOLD THE RX-7!
there is no fluid in the brake booster, any leaking oil is from the master clyinder. and my rpms drop when I step on the pedal too...
Old Feb 28, 2002 | 11:50 PM
AKABILLY's Avatar
RPM'S
So it's normal for the RPM's to drop some when hitting the brake? If that's the case that makes me feel better. You ever replace the booster?
Old Mar 1, 2002 | 01:43 AM
Dirtking's Avatar
When you hit the brakes...they cause a large drain in the charging system and your alternator cranks up.. putting little more strain on motor....
I only had to change my booster when i went to non-ABS brakes.
Old Mar 1, 2002 | 08:40 AM
Wankel7's Avatar
Haven't we ALL heard this
AKA, you missed what Scott said. The brake booster does not contain fluid. If anything is leaking it is the master cyl. That is what needs to be checked into. Unless you wanna throw money at the brake booster. From what I have learned these cars like money being thown at them
James
Old Mar 1, 2002 | 11:23 AM
RETed's Avatar
I concur.&nbsp The brake booster is not the problem.&nbsp What you're describing is the brake master cylinder leaking.&nbsp Mine did the same thing, and I have a "scarred" brake booster to prove it too!
-Ted
Old Mar 1, 2002 | 12:22 PM
defylogik's Avatar
ive replaced the booster on my old car. it was malfunctioning and causing a mush pedal. it was straight forewared. but read above, your MBC is leaking! get a rebuild kit or a new one from mazdatrix.com
scott.
Old Mar 1, 2002 | 12:30 PM
AKABILLY's Avatar
Thumbs up Brake booster
Cool, thanks for the advice! Brake Master Cylinder replacement here I come. The BMC gets used as an elbow rest when changing the plugs and Oil filter. I'll have to mark it "NO STEP" in Bright orange to remind myself.
Thanks again.
Old Mar 1, 2002 | 12:32 PM
RETed's Avatar
You can lean on it all you want.
It's the internal seal that fails and the fluid leaks out the back.&nbsp The seal between the brake master cylinder bore and brake booster isn't air-tight, so it's going to leak back there.&nbsp If it were sealed, all that fluid ends up on the foot insde the car!
-Ted
Snoopy FD
Dec 8, 2015 01:45 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
