APEXi BOV Help
Old Sep 22, 2006 | 09:31 AM
X Factor's Avatar
APEXi BOV Help
Does anyone know where I can find info/instructions for the APEXi TWIN CHAMBER BOV?
Old Sep 24, 2006 | 06:56 PM
marcus219's Avatar
FC Mobsta
its super easy to hook up man. just loop the two ports on the side with a vac. hose. then the top when gets manifold pressure. simpy as that. block off that little port on the replacement pipe if your running ems or no emissions.
-marc
Old Sep 24, 2006 | 06:58 PM
NeedFD's Avatar
R. R. R.
http://www.apexi-usa.com/support_installation.asp
http://www.apexi-usa.com/pdfInstallation/35.pdf
Old Sep 24, 2006 | 09:36 PM
marcus219's Avatar
FC Mobsta
noice. i didnt even think to go on the website when i did mine. nice link mayne
Old Sep 25, 2006 | 01:04 PM
X Factor's Avatar
Thanks for the info guy's. It's installed correctly, what prompted my question is I that hear it blowing off every time I lift off the accelerator even with no positive boost. Still breaking in an engine so I'm staying off the boost which why I'm surprised to hear it. Seems like it may be a little sensitive. Just looking too see if anyone has a step by step procedure for finding the right balance of response and protection that has proven successful.
Thanks for the pdf’s. I’ve looked at the APEXi web site and couldn’t find the documentation, never figured it would be under ‘Support’. Usually ‘Support’ ends up being some email link or phone number you never hear bake from.
Old Sep 25, 2006 | 04:22 PM
marcus219's Avatar
FC Mobsta
adjust the spring like it says and it should be fine. mine will vent at like 4" of vacuum under some load. like 4th or 3rd. try adjusting that spring tension
