Differences between kits and universal?
Old Feb 27, 2002 | 03:59 AM
MtnRacer's Avatar
infini guru
What the difference between buying, say, an HKS BOV kit for an rx7, and buying an HKS BOV universal kit and flange specific to an rx7? Does the Kit come with a swappable pipe with already-welded flange on it? or what?
Old Feb 27, 2002 | 09:48 AM
RETed's Avatar
BOV "kits" specific to your car come with an adapter pipe that makes everything a drop-in install.&nbsp Universal BOV's usually implies you'll just get the BOV itself - you'll need the mount flange to weld somewhere onto the intake system.
-Ted
Old Feb 27, 2002 | 02:17 PM
MtnRacer's Avatar
infini guru
So what'll it run me to have the flange welded onto my stock pipe? I'd do it myself, but as I have ZERO welding skills the last time I checked...
Old Feb 27, 2002 | 02:30 PM
goodspeed's Avatar
Talking ....
by the kit from rx7store.net. its 289. and it drops right in. Ill spend the extra money to save some time and it looks a lot better.
However, there is no need to upgrade the bov unless you are running more boost 10 psi > or something wrong with the stock one. its a waste of money.
Im running 10psi and my stock bov was leaking causing a rough idle. Thats why I bought the hks ss. Its the best with the dual chamber design.
astrum
24
Nov 15, 2017 08:44 AM
GrossPolluter
Aug 22, 2015 11:23 PM
