new set of turbos, ? on how do i tell if i have turbos with pills on the nipples
Old Feb 27, 2002 | 12:03 AM
TainoIndian's Avatar
i mean i new turbos on my car i checked the line and it doesnt have any pills? i looked at the turbo pipple and it looks normal to me? but i heard that on newer turbos the pills are built into the nipples ( what would they look like) i definantly dont have pills in the vac hoses the mechanic must have thrown them out if there are supposed to be pills how do i know???
Old Feb 27, 2002 | 01:48 AM
max. tt boost's Avatar
Check the Wastegate and Pre-control actuator rubber hoses... Just squeeze them. You should find a small pill in the center of each hose.
jc.
Old Feb 27, 2002 | 07:14 AM
Brede's Avatar
There are only two pills, right?? Just did the hose-job, wanna make sure I got them all.
Old Feb 27, 2002 | 01:34 PM
rx7speed811's Avatar
Accepting Donations.
did you compare the inner diameter of the nipples on the new turbos to your old ones? if you cant tell, you can always just drive and see how it boosts. those hoses are not too hard to get to in the case you do need to put some restrictor pills in.
Old Feb 27, 2002 | 02:47 PM
hmmm
where can i get replacement pills from
FD7KiD
15
Feb 26, 2021 10:12 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
NJ-JDM
43
Aug 23, 2015 11:02 PM
FD7KiD
Aug 17, 2015 11:50 PM
