what wastegate on greddy TD06 20g kit?
Old Sep 3, 2006 | 04:18 PM
-stig-'s Avatar
hello!
someone have this kit, and can tell me what wastegate that fits?
i have a kit, and it seems like the wastegate that followed does not fit, i think its a TypeS, so would it be the bigger TypeR that fits?
regards,stig
Old Sep 3, 2006 | 08:25 PM
NeedFD's Avatar
R. R. R.
what is the footprint on it? also what is the length between bolts? that way other users can help you figure out, my guess it's the type R, but it could also be something else, so give some more info pls
Old Sep 3, 2006 | 09:20 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
These are the measurments of my wastegate flange which is a Greddy type C. I belive the smaller type R has teh same footprint
what does yours measure
-Jacob
Old Sep 4, 2006 | 02:25 AM
-stig-'s Avatar
the flange is 2 1/8'' x 2 1/8'' and 1 9/16'' between the bolts on the wastegate that followed the kit. the flange on manifold seems to be the same as CrackHeadMel wrote..
so, i have recived the wrong wastegate?
and, it would not be any problem for me to weld a flange and make it fit, but would this wastegate i have flow enough for me? or can i get boostcreep?
thanks for all answears!
regards,stig
Old Sep 4, 2006 | 04:28 AM
You could just cut off the flange and weld on the corret one. Titanmotorsports.com has them available if you call, however being your on the other side of the world, it would be cheaper if you just brought your wastegate to a machineshop and had them make you a flange
Old Sep 4, 2006 | 05:33 AM
-stig-'s Avatar
so it would not be any problem with boost creep and the sice of the wastegate?
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
