Is this turbo worth the price please help
Old Aug 29, 2006 | 01:10 PM
slo's Avatar
slo
registered user
From ad"
I have a BRAND NEW in the box with gaskets, Garrett Turbocharger for sale.
T3/T04e
Compressor:
57trim
.60AR
Exhaust:
.63ar
stage 3 wheel
4-bolt exhaust outlet
$500 FIRM!!"
How much power with this make on a stock port 13bRE with a good tune at 15 PSI.
Thanks..
Old Aug 29, 2006 | 01:20 PM
RacerXtreme7's Avatar
NASA geek
eBay junk, its WAY too small for a rotary.
~Mike..........
Old Aug 29, 2006 | 02:24 PM
slo's Avatar
slo
registered user
Not ebay, its sold localy still in the original box, has all the apropriate marking to be a real garrett and is new.
Thanks for the reply, and any idea on how much power from 15 psi?
I am looking for quick spool and about 350 WHP. I have a 13b RE currently on stock twins, with a haltech E8. walbro pump, 1680 secondairies, big intercooler. It makes 260 WHP on a very conservative tune at 11 PSI.
I have so far collected a good BOV and wastegate, and am looking for the remaining parts I need to go single on a low budget. I will most likley use one of those cheap manifolds ceramic coated by a local shop.
Is this turbo too small for my goals?
Old Aug 29, 2006 | 02:41 PM
slo's Avatar
slo
registered user
pictures attached...
Attached Thumbnails Is this turbo worth the price please help-w36uh7k5rpo6h9h0lyx99lzvfcav%5B1%5D.jpg   Is this turbo worth the price please help-1olurimixmngv1v1bofhxna2tn7z%5B1%5D.jpg
Old Aug 29, 2006 | 03:07 PM
Turblown's Avatar
Turn up the boost
Turbine section is way too small as said...
Rotary Performance Parts
Old Aug 29, 2006 | 03:09 PM
hondahater's Avatar
spending too much money..
boby beach can sell you a masterpower t61 or t70 for around that same cost.
Old Aug 29, 2006 | 03:14 PM
slo's Avatar
slo
registered user
Are masterpower turbo's good?
Arent those the turbo's XS power sells for 300 dollars that last 5 minutes?
No insult meant if I am wrong.
Old Aug 29, 2006 | 04:10 PM
hondahater's Avatar
no master power is a good quality turbo that got a bad name buy xs power and ssautocrap putting pictures of masterpower turbos and thier boxes on thier listings. There are quite a few here that have masterpower turbos including bdc, slammed7 etc... Talk to bobybeach on this website.
Old Aug 29, 2006 | 04:11 PM
tdazmansFD's Avatar
Out of the game
Did'nt post fast enough lol /\
NO. XS Power is not the same as MasterPower. MasterPower is a decent turbo.
Pony up a couple of hundred more for a Turbonetics 60-1 or 62-1 (Ebay for $750 New) or go with something similar.
I have a Borg Warner T04b that's almost new I'm going to sell if you insist on that size of turbo. $275 shipped if you're interested. PM me.
Old Aug 29, 2006 | 04:15 PM
EZFD's Avatar
nice looking turbo, just too small of a turbine
Old Aug 29, 2006 | 04:51 PM
slo's Avatar
slo
registered user
here are more specs, just out of curiosity what will this turbo make at 15 PSI boost
http://cheapturbo.stores.yahoo.net/gat357trw63a.html
Old Aug 30, 2006 | 03:03 PM
Madrx7racer's Avatar
jujst buy a BNR hybrid......stage 2 should put you in the 300-360 hp range.
Old Aug 30, 2006 | 04:25 PM
NASA geek
You need to reSEARCH and figure out your power goals, how the car will be used (weekend drag car, daily street car, high speed track car etc) to determine what turbo system works best for you. THEN, you need to realise the supporting mods for it (exhaust, intercooler, intercooler piping, fuel upgrades such as injectors, pumps, regulators, then engine management ETC ETC ETC ETC. Simply plucking links online and asking for power figures will get your no were, or at best end you up with either a none usable turbo for your car, or something that does not respond how it should for your driving style and or requirments. The turbo you just linked is worthless on a rotary it is near the same spec turbo as you posted originally. It has a T3 turbine wheel and turbine housing, you need a T4 turbine. And before someone chims in and says "gt35r and or Rx6 is a T3" is wrong. They have a T3 bolt pattern/flange, but the turbine wheels are T4 sized so save your ignorant comments.
Search, theres a-ga-zillion threads on what turbo is good for what power at X psi and how it responds. Theres tons of info on this and other rotary related forums. Theres many here who will help (such as me), but having to explain an entire build and holding ones hand gets redundant and agrovating when all you need to do is a little research for yourself. Sorry to come accross as an ***, but you have a lot to research. At least list your goals and pick a few turbos out that are at least usable on a rotary engine. Then you might get better info as to help you make a final decision that you'll be satisfied with and a better understanding of your car.
Off the soap box for now...............
~Mike..........
Old Aug 30, 2006 | 05:25 PM
slo's Avatar
slo
registered user
I have all the supporting mods in place, haltech E8, 550/1680 combo big intercooler etc. My car is running and driving on stock twins. It is an FC btw with a 13bre.
I am turbo ignorant. And there is lots of contradicing info on all the forums.
Old Aug 30, 2006 | 05:42 PM
Turblown's Avatar
Turn up the boost
Thats because A) different people believe different things, and B) this is the internet, so many people just repeat what someone else has said as if they are talking from personal experience, which most people don't have, and if they do its very limited.
Old Aug 30, 2006 | 05:43 PM
well, to me it's a given............If you're buying a turbo you HAVE all the mods to make sure your motor is safe..........Check out BNR......
cristoDathird
28
May 30, 2019 08:47 PM
cam_7779
Aug 18, 2015 07:48 AM
