Performance Alternator Question
Old Aug 15, 2006 | 05:10 PM
FFXLuc's Avatar
I am new to this forum but i'm an avid poster in MNPOC and Probetalk, Now I own a 1983 Mazda RX7. 1.1 Carburated, Its My First carburated engine car i've owned and I love modding so... I'm buying Gold Battery connectors and a Chrome 100 amp alternator, is it ok to run a 100 amp alternator in such an old car or do i have to modd other things first to make it run right? thank you.
Old Aug 15, 2006 | 05:24 PM
mcfly's Avatar
running a higher amp alternator only means you have more power at tap if you need to use it.
each electrical component will take what it needs to run and thats it.
the battery and alt usually have away of comunicating.
ie. a sensor built into the alt.
Old Aug 15, 2006 | 05:44 PM
FFXLuc's Avatar
Ok Sweet So I'm not gunna blow the battery by cranking up the amps in the alternator then? And my Battery shouldn't have to struggle as hard with te sound system i'm installing. thank you I jus needed a varification.
Old Aug 15, 2006 | 11:12 PM
mcfly's Avatar
your battery will have the exact same stress' applied to it.
your alternator will just be able to provide more juice to the battery.
A capacitor would weaken the blow of very big hits by a mono amp but it is really not nessecary.
but to answer the original question you will be perfectly fine with just putting in a bigger alt.
Old Aug 15, 2006 | 11:27 PM
FFXLuc's Avatar
Yup, Thank You For Your Help.
Old Aug 15, 2006 | 11:31 PM
now's Avatar
now
I would be adding a wire from the alt. to the battery if you are planning on adding
more stresses to the stock wiring.
it is true that everything should be fine as long as no more than stock load is not added.
if more than stock load is added the stock wire from the alt to the battery could burn.
matt
Old Aug 16, 2006 | 07:41 AM
speedturn's Avatar
The stock alternator output wire will be over stressed if it actually is required to carry 100 amps for more than a few seconds.
The Shaolin
Sep 14, 2015 07:50 PM
elfking
Aug 19, 2015 09:48 PM
