Answer me this.... oil out the dip stick...
Old Aug 7, 2006 | 07:31 PM
quick_spoolin's Avatar
I'm Single..Turbo that is
Arrow Answer me this.... oil out the dip stick...
here's what happens... When i get in to high revs like 5,000+ or when i boost oil just GOES CRAZY out my dip stick. it literaly shot my dip stick out... whats up????
Old Aug 8, 2006 | 12:50 AM
now's Avatar
now
side seal has failed.
do a paper compression test and you will see it.
Old Aug 8, 2006 | 11:18 PM
yodaddy's Avatar
second vote for dead side seal. what happens is the side seal break then let compression leak past, the oil control rings aren't strong enough to keep it out so it gets past them and presurizes the oil pan, that pressure then pushes your dipstick out and brings small chunck of oil with it.
Old Aug 9, 2006 | 08:04 AM
RETed's Avatar
Too much blow-by...
Most likely tired motor or tolerances too loose on the rebuild.
-Ted
Old Aug 9, 2006 | 07:41 PM
Tim Benton's Avatar
FD title holder since 94
Possible PCV went bad, stuck open and that is pressurizing the oil pan area?
Tim
Old Aug 11, 2006 | 02:10 AM
R.P.M.'s Avatar
Likes to swear....alot
So really....a properly built motor should have no blow-by at all....
Thats really weird because almost every turbo'ed rotary I've ever seen blows oil out the little vent on the center iron or out the dip stick lol
Old Aug 12, 2006 | 10:12 AM
Tim Benton's Avatar
Help us out and post the engine builders and installers of those engines your talking about blowing oil like that. I want to steer people away from them or those who installed it. No oil should not be blowing out like that.
Tim
Old Aug 12, 2006 | 10:52 AM
BASTARD's Avatar
Whoa there people, before blaming engine builders ... we should probably make sure the installer has installed it correctly first.
If you had a bad side seal most likely you would see a ton of smoke when the motor is under vacuum. This would be at idle, off throttle cruising and most obviously during deceleration (especially heavy deceleration)
I would say double check your vacuum lines to make sure that you are not running a vacuum line to the "crank case” while under boost.
The Factory PCV system uses solenoids and check valves to vent while on or off boost to keep from back pressuring the system. If you still have this system in place then you need to diagnose if it is working properly...
If you do not still have this sytem in place then you will rethink the venting system routing by adding blow by tanks and/or check valves etc...
Old Aug 12, 2006 | 09:47 PM
Tim Benton's Avatar
Notice I did say builders and installers...both need to be examined to determine the cause of the oil coming out like that. You brought up some good things to look at as well. Hoprefully we can steer him in the right direction and his engine build quality isn't the culprit.
Tim
Old Aug 13, 2006 | 12:14 AM
now's Avatar
now
a good point to ask before i posted my answer would have been is this something
that just started to happen or is this something that has started up after
an engine change?
matt
Old Aug 13, 2006 | 09:37 PM
ErnieT's Avatar
Living life 9 seconds at a time
I had the same problem with an engine about 1.5yrs ago. Like stated earlier, its blow by caused by a weak engine.
The1Sun
Mar 18, 2018 11:08 PM
Microtech
30
Apr 23, 2016 06:37 PM
rotor_veux
Sep 3, 2015 07:10 PM
