Power FC logging locks after .5 to 8 seconds?????
Old Aug 3, 2006 | 01:40 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
i have been running my PFC/Dataloggit for a number of years and all of
a sudden i am unable to log more than 1 to 8 seconds. it just locks. i
have tried varying the coverage, basic advanced etc to no avail. i
deleted a bunch of old logs just for kicks but that had no effect. my
computer has plenty of available space. i am not using the commander.
i am running V 1.090.
i am just shaking down a methanol injection system as well as a few
other things so i decided i didn't want to have to deal w the newest
Datalogit version should it have some initial bugs.
i sure would appreciate any help... i did a search and didn't come up
w anything in the archives.
howard coleman
Old Aug 5, 2006 | 09:25 PM
Asleep's Avatar
7 Rx-7s since 1980
howard coleman
Howard,
Did you check the connector on the PFC? Had issues with a bad connector a few years back. Sent you an email.
Tony
Old Aug 5, 2006 | 09:35 PM
yes. thanx for the help tony. the connector is fine. i am switching laptops monday and datalogits tuesday. BTW, i do have one of the first PFCs but it has always run flawlessly.
howard
Old Aug 5, 2006 | 09:37 PM
should i upgrade from datalogit V1.090 or might that cause further problems?
Old Aug 6, 2006 | 09:07 AM
cewrx7r1's Avatar
Eye In The Sky
Howard,
Your problems seems more like a hardware/software of the laptop than the FC-Edit version. If you have the install zip and upgrade zip, try re-installing from scratch. If it still locks up, then it is your laptop.
I have never has your problem.
Chuck
Old Aug 6, 2006 | 07:14 PM
thanks Tony and Chuck... i appreciate your help.
i loaded the newest Datalogit version today and am happy to report that it solved my problem. it appears, also, to have a base fuel/AFR automatic calculator so i might not need to use my Excel file to do the numbers...
remember back in the old days when we had to get a calculator out and do the math for all the cells?
thanks again,
howard coleman
Old Aug 13, 2006 | 03:14 PM
I'm having a similar issue. My map watch is frozen at the P01 N01 position, it does read AFRs but it wont change map position. My map tracer does work on occasion and my monitor always puts out the right numbers its just a PITA to tune with just lines of code. I'm running 2.101 and I have yet to be accepted to the yahoo group. Would anyone have any insite to this problem?
Old Aug 13, 2006 | 10:47 PM
cewrx7r1's Avatar
Eye In The Sky
The older software versions of the UNIVERSAL DL had problems and the current version is 2.113. It still can not do a DAT file comparison and who knows what other problems it still has. I only use the UNIVERSAL software to play with as I do not have it's hardware.
I have the older FD3S version which works PERFECTLY!!!!!!!!!!!!!!!!!!!!!
Old Aug 14, 2006 | 03:38 AM
think someone could email me a good version? mark_biernacki@hotmail.com
Old Aug 14, 2006 | 09:18 AM
cewrx7r1's Avatar
Eye In The Sky
Sent!
Old Aug 14, 2006 | 09:25 AM
peluca's Avatar
Could you mail me that ver. too? Please. Thanks.
peluca_fernandez@yahoo.com
Old Aug 14, 2006 | 12:54 PM
cewrx7r1's Avatar
Eye In The Sky
Done!
Old Aug 14, 2006 | 01:03 PM
peluca's Avatar
Thanks.
Old Aug 14, 2006 | 01:08 PM
thanks chuck we'll see how she works
BUSTN
Sep 21, 2015 05:01 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
TwentyDW
Sep 2, 2015 06:42 PM
