T04R oil line pressure
Old Jul 28, 2006 | 06:48 PM
BuckyFD3's Avatar
GT4088R
What oil line pressure does this turbo use?? What size restrictor is best considering I am using crank oil jet mods so the pressure is lower than normal.
Or the size of pipework.
Basically I need to make an adapter to fit over the oil gallery, but will be 1/4inch pipe then tig a restrictor on the end to screw the oil feed on.
Make sense?????
Old Jul 28, 2006 | 08:21 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
this is what im running in my t04s
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
-Jacob
Old Jul 29, 2006 | 02:35 AM
signofinfinity's Avatar
Coyote
-3AN fittings and pipe. thats just right.
Old Aug 2, 2006 | 11:01 AM
FD3S_wanted's Avatar
Here is the answer I received from cheapturbo. My TO4R comes from them:
If its the standard bearing we still do not advise to run a oil restrictor we don't run them if you have a good oil return and a standard -4 line you will be fine
Old Aug 2, 2006 | 11:21 AM
Zero R's Avatar
Just in time to die
I would not run this on a standard bearing turbo you will starve it of oil, I would run a -4 line and -10 return.
-Jacob
Old Aug 2, 2006 | 05:59 PM
teknics's Avatar
im going to be running a t78 with a -4 feed and -10 return... do i need a restrictor?
kevin.
Old Aug 3, 2006 | 06:19 AM
Zero R's Avatar
Just in time to die
No
Old Aug 3, 2006 | 07:25 AM
SilvioRX7's Avatar
What about a GT40R, what size feed and do I need a restrictor?
-Silvio
Old Aug 3, 2006 | 03:42 PM
BuckyFD3's Avatar
GT4088R
What inner Diameter pipe is -4 and -10??
Old Aug 3, 2006 | 04:41 PM
i have over 9k miles on my turbo with that restrctor, no shaftplay to date
Old Aug 4, 2006 | 06:33 AM
Zero R's Avatar
Just in time to die
-4 is equal to .25" -10 is equal to .625" the smallest diameter recommended for the drain .5" you can run .5" with no issues at all but it has to be a smooth bend, no kinks.
Old Aug 4, 2006 | 06:46 AM
BuckyFD3's Avatar
GT4088R
ok thanks
Old Aug 7, 2006 | 04:55 PM
black beauty's Avatar
no oil restrictor here on my t04r
Old Aug 7, 2006 | 05:02 PM
BuckyFD3's Avatar
GT4088R
I am running atkins oil jets mods so the pressure is going to be lower than a normal FD
FD7KiD
15
Feb 26, 2021 10:12 PM
BLK 93
Aug 19, 2015 03:47 AM
FD7KiD
Aug 17, 2015 11:50 PM
