Old 07-23-06, 09:25 PM   #1
nigorx7
nigorx7's Avatar
Rtek 2.0 and t04s
I would like to know if the RTEK 2.0 would be able to tolirate my modification?
MY set up:Turbo hybrid to4s
external wastegate
fmic
3" straight pipe exhaust
bov
4x 720cc injector
cold air intake
walbro fuel pump
Centerforce dual friction clutch
I would like to boost up 12psi,Is it possible?
nigorx7 is offline   Reply With Quote
Old 07-24-06, 08:00 AM   #2
X-JaVeN-X
Drive.
X-JaVeN-X's Avatar
Send a message via AIM to X-JaVeN-X
i don't see why it couldn'tt
X-JaVeN-X is offline   Reply With Quote
Old 07-26-06, 03:22 AM   #3
Henrik
Should be fine. You should at least tune with as wideband to ensure that your not
leaning out. Keep an eye on the AFM sensor and max duty cycles (on the log screen)
during tuning to make sure you not maxing either. You'll probably want to pull a bit of
timing as well.
-Henrik
Henrik is offline   Reply With Quote
Old 08-02-06, 12:38 PM   #4
sonick117x
the crowned prince
sonick117x's Avatar
dont flame me.. but what is controlling the boost to 12 psi?
sonick117x is offline   Reply With Quote
Old 08-02-06, 08:37 PM   #5
nigorx7
nigorx7's Avatar
Turbosmart manual boost controler
Old 08-03-06, 01:14 PM   #6
sonick117x
the crowned prince
sonick117x's Avatar
thank you.. that was probably the most straightforward answer i could ask for
