ever mess w/ the rich/lean screw?
Old Feb 21, 2002 | 11:28 PM
Papasmurf's Avatar
Has anyone ever messed with this, it is on the passenger fender.
Old Feb 21, 2002 | 11:32 PM
crasher2's Avatar
I have mesed with mine, dont know if it helped any because my MAPs isn't set right
Old Feb 22, 2002 | 03:13 AM
Felix Wankel's Avatar
Super Newbie
Mines always on rich, just for the hell of it.
Old Feb 22, 2002 | 03:18 AM
Xcessive's Avatar
were is it
Old Feb 22, 2002 | 03:40 AM
RETed's Avatar
Keep in mind this only affects mixtures at idle.
-Ted
Old Feb 22, 2002 | 07:27 AM
Papasmurf's Avatar
Directly in front of the passenger fender.
Old Feb 22, 2002 | 08:25 AM
Grimlock's Avatar
how the hell
you get that stuff thats in there blocking the screw out, its all caked up and hard.
Old Feb 23, 2002 | 02:24 AM
Keith's Avatar
Been there, done that. The ECU will only pay attention to this setting when the Initial Set Connector is jumpered. On a warm engine idling at 750 rpm with the connector on, turn the screw until you achieve the highest idle. Readjust to 750 rpm if needed, re-adjust. That's it, your idle mix is now set.
Irv, Keith's dad
Old Feb 23, 2002 | 06:36 AM
HAILERS's Avatar
HAILERS
This jpg:
Old Feb 23, 2002 | 06:46 AM
HAILERS's Avatar
HAILERS
Well then this:
Old Feb 23, 2002 | 06:51 AM
HAILERS's Avatar
HAILERS
And this that should have been first;
Old Feb 23, 2002 | 11:12 AM
von's Avatar
von
HAILERS
Then what about the 89-91 engines. MY adjust screw is above the plenum. I adjusted it without a jumper. How would I do this?????
Old Feb 23, 2002 | 11:41 AM
Turblown's Avatar
Turn up the boost
i was told not to mess with this because your gas mileage will be horrible, don't know if theres any truth to it. I used a drill to cut out the black stuff in there.
Old Feb 23, 2002 | 11:47 AM
RETed's Avatar
Re: HAILERS
Only 1986-1988 Zenki FC's have this mixture screw...
-Ted
Sethix
Nov 3, 2017 11:48 PM
Andrew7dg
Aug 6, 2017 01:41 PM
Robrods64
Oct 2, 2015 07:56 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
