Gotham racing turbo blanket temp
Old Jun 21, 2006 | 09:06 PM
gonzz's Avatar
I just installed my gotham racing turbo blanket. How much should my eng bay temps drop? just wondering? Also how did you guys fasten it. I was thinking using wire on the tabs to hold it together.. Awsome Product..
Old Jun 21, 2006 | 09:36 PM
Nuvolari's Avatar
Veni, Vidi, Vici
I like mine, never ran my single without it, but it must work. Its cool to touch pretty quick.
Old Jun 21, 2006 | 09:47 PM
BDC's Avatar
BDC
BDC Motorsports
Hey Gonzz,
I use the same type of blanket on mine. Not sure if it's the same manufacturer or not. Engine bay temps should drop drastically depending on the setup. Also, you'll notice your water and oil temps will be less likely to rise under load. They'll be easier to control. As far as tying the blanket down, I just "sit" mine on. It's not really tied down so there's evidently no need for wires on the tabs.
B
Old Jun 21, 2006 | 10:29 PM
gonzz's Avatar
Originally Posted by BDC
Hey Gonzz,
B
Thanks for the info.. Gonna drive it tonight and see.. All i need now is to make a heatshield between my downpipe and lim...
Old Jun 22, 2006 | 08:49 AM
rotorbrain's Avatar
fart on a friends head!!!
is your wastegate plumbed to the inside of your car??? please tell me there is a dump-pipe for it. . . to be honest, you might wanna put a heat shield on the wastegate and its dump-pipe as well. that this is bound to cause AT LEAST premature thermostat failure.
Old Jun 22, 2006 | 02:43 PM
1wide7's Avatar
i used wire on the tabs and its holding strong
Old Jun 22, 2006 | 04:02 PM
BDC's Avatar
BDC
BDC Motorsports
GREAT idea!! I've been tossing the idea around of having a sheet heat shield made for quite some time perhaps w/ some Thermotec heat matte stuff or whatever...
B
Old Jun 22, 2006 | 04:36 PM
Fish's Avatar
What about just wrapping the DP? This will kill a lot of the heat.
Fish
Old Jun 22, 2006 | 05:37 PM
gonzz's Avatar
I made a dump pipe for my wastegate. Going to weld it on the V-band this weekend. My manifold is ceramic coated but might wrap it anyway...
Old Jun 22, 2006 | 05:39 PM
gonzz's Avatar
B
BDC: What heatshield do you recommend bettween the downpipe and LIM? I need to get one.. This Vegas heat is rough.. today is 110 outside..
Old Jun 22, 2006 | 05:52 PM
HedgeHog's Avatar
Rotary Poseur
Check out Pettit's Cool Power System (a bit pricey). It seems to be what you guys are discussing: http://www.pettitracing.com/rx7/index.htm
Old Jun 22, 2006 | 06:38 PM
gonzz's Avatar
Nice, I think i will get a sheet of SS and wrap some heat barrier to it. Will save some $$$.. Thanks for the link
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
