Weld in a bung for Wideband O2 sensor
Old Jun 19, 2006 | 07:58 PM
jkstill's Avatar
Searching for 10th's
Can someone recommend a shop in the Beaverton area that can put a bung in downpipe?
I mean, put one in, and do it right?
I'm really getting tired of giving people money to do a job, and getting garbage in return.
The bung I had welded in at a local muffler shop (Ed's Muffler in Beaverton) doesn't hold water. Literally. The welds didn't look too good, and they weren't. I poured some water down the pipe, and it leaks out around the welds.
I just need someone to fix it now I guess. Not going back there.
Old Jun 20, 2006 | 12:43 AM
I can do it for you. Drop it off at Apex Restoration 12225 SW Millikan Way in Beaverton. Tell them your droppng it off for Adam(Moto) to fix it. Give me a call 503-320-6495. The welders I have access too posted.
http://maps.google.com/maps?f=q&hl=e...,0.026779&om=1
Old Jun 21, 2006 | 12:25 AM
pp13bnos's Avatar
Pineapple Racer
Might be able to talk to Ralph at GZ or Rob at Pineapple. Bolth guys know you. CJ
Old Jun 21, 2006 | 12:44 AM
Well I fixed his FUBARed downpipe, jesus, whoever did this doesn't know how to weld. I ground off what I could and then did two layer of stainless. I also removed his heat shield material transfer and the sharp ends off the midpipe mounting plate.
Old Jun 21, 2006 | 01:12 AM
jkstill's Avatar
Thanks, I was going to call them next.
The guy that does the welding at GZ does very good work, as does Rob.
I've been running around so much, I was trying to find someone closer to home to cut down on my driving. Should've known better...
IAC Adam took care of it today and did a great job.
