Old 06-16-06, 03:22 PM   #1
Digi7ech
I break Diff mounts
Digi7ech's Avatar
Send a message via AIM to Digi7ech
Streetport on 1.7?
I've got a SP and am contemplating getting 720's and 1.7 to help with fuel.
You think it can handle it?Maybe only run 10psi?
I can't afford the 2.0 yet so this is a bandaid fix since I've already got 1.5 so it's $25 to go to 1.7.
88 GTU w/3mm atkins 13bt TII conversion// Now track car //206rwhp @10.4psi //14.2 @10.4 psi in 1/4 mile
Project Daily drifter// Scrapped and parted
87 TII build
89 240sx Hatch : New daily beater
Digi7ech is offline   Reply With Quote
Old 06-17-06, 04:16 AM   #2
demahfahbun106
Psychotic CRITIC™
demahfahbun106's Avatar
Send a message via AIM to demahfahbun106 Send a message via MSN to demahfahbun106
sure
i dont see why not...plus you said you going to be runnign 10psi, even better
demahfahbun106 is offline   Reply With Quote
Old 06-17-06, 07:14 AM   #3
brooklynfc3s
brooklynfc3s's Avatar
are u really sure? If you've got money invested in your motor, I wouldnt risk it. You cant make any corrections with the 1.7. at least get a 2.0 and tune on a wideband or something.
brooklynfc3s is offline   Reply With Quote
Old 06-17-06, 05:10 PM   #4
Digi7ech
I break Diff mounts
Digi7ech's Avatar
Well. I guess it should hold pretty well.
The engine just eats more air and all the ECU does is add fuel dependant on the AFM readings. The AFM will be noticing the increased air so it will match it.
As long as the 720's don't hit their max I should be fine.
So if on stock port a 1.7 can hit 12-14psi then a streetport at 10psi may be relatively the same.
I think I'm going to run stock levels and try and borrow a wideband to see how far up I can go before it starts going lean.
I would prefer to just run 10psi still.
Old 06-22-06, 05:17 PM   #5
Digi7ech
I break Diff mounts
Digi7ech's Avatar
Got the 720's and stopped by Digital Tuning today to get my ECU redone.
I expected to just drop it off.
He kicked ass and did it on the spot for me AND i got a cool license plate frame.
Old 06-22-06, 05:57 PM   #6
ePH C freak
Passenger
Posts: n/a
^ yeah, digital tuning custumer service ROCKS! i'm not surprised they did it on the spot.
anyway, as far as the streetport goes with the rtek1.7, i don't know anyone who's done it, but i'd say to get atleast 750cc injectors as secondaries... or even upgrade to the 1.8 version instead (so that you can use 720cc primaries), just to be sure that fuel compensates for the extra air...
Old 07-02-06, 04:20 AM   #7
drugblock12a
WON'T FORGET DAVE
drugblock12a's Avatar
I am planning on useing the 1.7 on a streetported 87 T2 block. I don't plan on running anymore than 10 pounds. If anyone has run a similar setup please chime in.
drugblock12a is offline   Reply With Quote
