3psi is barely anything. It's not a "oh we're in boost, start dumping fuel" thing. And it's not a "We're 1 psi of boost, we need to run 11:1" thing either. Its a gradual thing. I don't even think you are in open loop at that point. The AF will vary depending on load. Log the widband, rpm, and boost. Go to third or fourth and gradually go from 0% thorttle to 100% throttle. You should see the A/F be gradual, but my jump at the point you go open loop.
