turbo problems, need some help
Old Feb 18, 2002 | 11:19 AM
kevino's Avatar
recently my turbo has been sounding terrible. Instead of that beautiful whirr of the turbo spooling up, it just sounds ratty, like it's dragging while turning or something. It still gets the same boost it was getting before, it just sounds like hell. As a side note, I replaced my secondary injectors with 720cc's last year and ever since I did that my turbo builds up pressure and starts to spool before getting over 3500-4000 rpms. could this be a contributing factor to the problems i'm having with my turbo, and also, do any of you have suggestions of what is wrong with my turbo and how i could fix it?
thanks,
kev
Old Feb 18, 2002 | 12:13 PM
Josepi's Avatar
Despise Enmity
No, the injectors aren't going to make a difference unless you have them adjusted with some sort of ECU. Otherwise, you'll just be running rich.
To me atleast, it sounds like the bearings in the turbo are letting go. Take off the TID and check for play at the turbo.
Joe
EDIT: Your turbo should be spooling around 2.7K boost around 3K, for stock atleast (mine )
Old Feb 18, 2002 | 03:52 PM
kevino's Avatar
thanks joe, i'll check her out
Old Feb 18, 2002 | 04:38 PM
Josepi's Avatar
Despise Enmity
Another thing, do you have some way of controlling the bigger injectors? Why'd you put em on?
Old Feb 19, 2002 | 04:36 PM
kevino's Avatar
injector control
no, i don't have a way of controling them, I was just told, through asking various people, that beefier secondary injectors would make my car faster in the higher end. I put on a new air intake setup, so it is getting oxygen to match the richness, but I do not have any way of controling the secondaries.
Old Feb 19, 2002 | 04:42 PM
NZConvertible's Avatar
I'm a boost creep...
That extra air is metered by the ECU and fuel is added to compensate (not very well though). You'll be running too rich and losing potential power.
Old Feb 19, 2002 | 06:28 PM
kevino's Avatar
so, are you saying that if I get a fuel controler I could adjust my fuel/air ratio and possibly produce more power by having them even?
Old Feb 19, 2002 | 06:33 PM
Yes. Basically the leaner you run the more power you make, up to the point it starts to detonate. You should run slightly rich mixtures at full boost as a safety factor.
Old Feb 19, 2002 | 10:46 PM
kevino's Avatar
well, i have a lot of plans for my car this summer (when I have money, that is) and maybe I'll tinker with a fuel controler then, but utmost is having my turbo rebuilt and my engine overhauled.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
